Is there a way to get the docs in .mobi format
- Harry_Y
14 Dec 2011 03:16 #15657
by Harry_Y
Is there a way to get the docs in .mobi format was created by Harry_Y
I have a Kindle and if possible I'd like to be able to read the docs on in.
makes it nice when you are sitting on the couch, and cheaper than printing them out
PDF will work. but it does not format on the screen well.
- ArcEye
- Thank you received: 758
14 Dec 2011 09:17 #15664
by ArcEye
Replied by ArcEye on topic Re:Is there a way to get the docs in .mobi format
- Harry_Y
14 Dec 2011 13:53 #15679
by Harry_Y
Replied by Harry_Y on topic Re:Is there a way to get the docs in .mobi format
ArcEye wrote:
I can convert it from pdf but that typically does not work that well
The best would be if I can pull it down in HTML then convert from that using Calibre
- BigJohnT
- Thank you received: 1176
14 Dec 2011 13:57 #15680
by BigJohnT
Replied by BigJohnT on topic Re:Is there a way to get the docs in .mobi format
If you use a git checkout you can build the HTML docs locally.
- Harry_Y
14 Dec 2011 15:29 - 14 Dec 2011 15:31 #15681
by Harry_Y
BigJohnT wrote:
Off to figure out how to do this
Last edit: 14 Dec 2011 15:31 by Harry_Y.
- BigJohnT
14 Dec 2011 16:10 #15682
by BigJohnT
Time to create page: 0.065 seconds
