Will EMC work with any ISA card and controller box
15 Dec 2011 15:07 #15701 by 777funk
I've got an old ISA card system that uses a 3 axis amp and servos. I'd like to put Ubuntu or Red Hat Linux on the machine and use EMC if it's possible. It's a DOS based control at this point.
Curious what it would take to get it running EMC2?
15 Dec 2011 15:45 #15702 by BigJohnT
Here is a thread about a similar question.
linuxcnc.org/index.php/english/component...ew&catid=30&id=14519
AFAIK you would have to write a driver for your card.
I would use the EMC LiveCD to install and not mess about with red hat.
15 Dec 2011 15:49 #15703 by PCW
I think there are two problems here:
1. Finding a Host CPU with and ISA slot that also has enough memory and performance to run Ubuntu.
Not sure what the exact limits are but I suspect than anything less than 256-512M of RAM and a 700 MHz processor will cause trouble. Its unlikely the original DOS based CPU has enough resources to run Ubuntu
2. Like John said, writing a driver for your ISA hardware. This may or may not be difficult depending on the hardware design and whether you have register level hardware documentation.
15 Dec 2011 15:59 - 15 Dec 2011 16:11 #15704 by 777funk
Excellent and thanks! I have the first part (a host PC with sufficient hardware to function).
The second Part... how would I even begin? I'll read the link given in the above post. But as far as writing drivers, I've programmed microcontrollers and have done some other programing. I have a little bit of background. But I've never done anything with drivers.
I do have the DOS installer. I guess I could reverse engineer maybe??
Last edit: 15 Dec 2011 16:11 by 777funk.
15 Dec 2011 16:22 #15706 by PCW
Do you have register level documentation for your ISA interface card?
Without this there's not much hope unless you like reverse engineering...
There is a skeleton driver (hal_skeleton.c in /src/hal/drivers) that covers the basics of whats required.
Also take a look at the other driver sources in /src/hal/drivers, for example the hal_stg.c code is for a ISA servo interface card with digital and analog I/O and encoder counters.
Time to create page: 0.072 seconds
