configering Home switches
- helpmeout
28 Dec 2011 23:45 #16061
by helpmeout
configering Home switches was created by helpmeout
If i put home switches on all three of my axis in a parallel configaration that is three switches hooked up to one input, (pin 11) on my Breakout board. if it hits one switch for home will it allow the machine to move to the other switches to finish homing the remaining axis. how will this work.
- TarHeelTom
29 Dec 2011 05:56 #16065
by TarHeelTom
Replied by TarHeelTom on topic Re:configering Home switches
helpmeout wrote:
You cannot tell the machine to home all three axes at once.
When you first load emc2 (on a three axes configuration) the "X" axis is the default selection. When you click the "Home" button, it moves the machine toward the X axis home switch, unless the switch is open. Once it finds the switch, it then backs away, and lets the switch close, then moves toward the switch at a slower rate. Now the computer knows where the machine is, in the X freedom.
Then you click on the "Y" axis (or the "Z" if you desire) and the process repeats itself.
If you're hooking all three home switches to the same pin, the computer has no way of determining which axis has hit the home switch, so it will only try to home one axis at a time.
However, in many cases, you are going to be using the same switch for home and limit. So, rather than wire your home switches in parallel, it'd be better to wire them in series. This means that a broken wire, or bad connection will always look like you have arrived at a limit switch, and stop the machine.
And if you do it right, it is sometimes possible to use the same switch for BOTH limits on any given axis. If you use a micro switch positioned under the (moving) table, for instance, you can use a tapered block near each end of the table to activate the same switch. In other words, in some cases, you could achieve all both homing and limits with only three switches.
Tom
Tom
- BigJohnT
- Thank you received: 1176
29 Dec 2011 12:02 - 29 Dec 2011 17:44 #16071
by BigJohnT
Replied by BigJohnT on topic Re:configering Home switches
You have to set the home sequence for each axis different so the home one at a time.
linuxcnc.org/docview/html/config_ini_config.html#sub:[AXIS]-section
Last edit: 29 Dec 2011 17:44 by BigJohnT.
- helpmeout
29 Dec 2011 17:06 #16081
by helpmeout
Replied by helpmeout on topic Re:configering Home switches
then the input for those switches are high or five volts, and when the axis causes the input to go low or ground it backs off so the other axis can do the same thing, this must be in the emc2 program,am i thinking correct on this and should inputs be isolated on the breakout board from ground, my breakout board can be set high or low inputs. also can you set the backoff distance that the axis backs off from the switch after it finds it and if you can how is that done.thanks so much for the info so far.
- ArcEye
- Thank you received: 758
30 Dec 2011 07:56 #16113
by ArcEye
Replied by ArcEye on topic Re:configering Home switches
Hi
I presume your query derives from wanting to use the fewest inputs possible.
Whilst in theory it sounds that you could have 3 home switches in parallel, even if you could get EMC to work with that logic, it would be a pig to use in practice.
The EASIEST way to have full home and limit switches for 3 axes, takes 4 inputs.
Each home switch has its own input and all the limits are chained together in series (NC switches)
Then you can set the homing sequence with ease to whatever you like, X, Y, Z or all of them together.
If a limit is triggered (which it should not be if you have set soft limits) a glance will tell you which axis it was.
This leaves 2 inputs on the BOB, 1 may be required for a charge pump and the other for a spindle index say.
Any more inputs required and fit a PCI parport card ($10). It is always easier to do things that end, than alter wiring on the machine.
- Rick G
- Thank you received: 155
30 Dec 2011 12:18 #16116
by Rick G
Replied by Rick G on topic Re:configering Home switches
You might want to look here...
www.linuxcnc.org/docview/html/config_ini_homing.html
You can have an axis hit the home switch, then back off the switch and then the next axis do the same, etc. if they are sharing the same home pin should not be a problem.
Rick G
Rick G
Time to create page: 0.071 seconds
