I'm driving the motors at 24V at 2.2A. The motors are rated at 2.5A. I will try running the tests you pointed out. I see that the test program points out if I have a problem, but what is the best way to choose the values? I was pretty conservative when I did the initial setup, keeping the max velocity and acceleration low (This is a hobby setup and I did not see a need to push the limits for speed, particularly as I'm also learning at the same time).
While I didn't adjust acceleration in my engraving file, I did experiment with keeping the feed rate very slow- down to 0.1 ipm, and that did not affect losing steps- I still lost steps.
Looking back at the initialization files, I may have made a mistake in my calculation with respect to adjusting for step size- I had calculated the step size multiple with respect to the X/Y, which is 32,000 microsteps per inch, while the Z is 20,000. Even with using a non-integral size, I shouldn't be losing steps, right? Particularly if I'm just transitioning between 2 different Z positions, one for cutting, and the other for moving to the next spot.
Thanks for the help. This software (and community) is pretty awesome.
