- Thank you received: 202
high microstepping values and steppermotors that cannot move these extreme small amounts
the higher the microstepping the worse these results become , as a stepper motor can only move one step at a time i.e 1.2 degrees , and the electronics of the microstepper driver trying to interpolate the microsteps
which cannot be achived , however EMC can calculate the move , so therefore you build up an error over time .
The plot does show the Z tool level changing- I did some experimenting and I found that it is only losing steps in a slow (G1) move, I had set the tool speed very low (F0.1 in the G-code) and the stepper was not moving at all, while I could see the back-plot changing. I sped *up* the feed rate during cutting to F2.5, and it was able to do the entire engraving cycle without losing any Z.
<snip>
I have never lost steps (I am aware of/have evidence of) in X or Y- the only real difference is the thread pitch on the feed- 32,000 microsteps per inch on X and Y, 20,000 microsteps per inch on Z.
One thing I still don't understand is that when I do a manual move at the smallest increment (0.0001) I can hear the motor moving (spindle off, of course)- that should be 2 microsteps. when I'm doing this move under the GCode at the slow rate, I can't hear the motor step at all, while I can see the back-plot showing a motion. Is there any condition that EMC would not actually drive the motor at the slow rate (I'm only changing one axis, the Z, when I notice this, so I don't think there would be any interaction with the other axes)
