One for the hardware gurus
02 Jan 2012 11:02 #16203 by ArcEye
Replied by ArcEye on topic Re:One for the hardware gurus
I knew they came from abroad, US was an assumption
1 Czech Krona = £0.0326328004
Happy calculating!!
02 Jan 2012 12:13 #16205 by BigJohnT
Replied by BigJohnT on topic Re:One for the hardware gurus
boldford wrote:
Many thanks for the kind offer of the 10/100 PCI card and the advice re wifi. I will mull over the option of running CAT 5/6 to the workshop as it'll involve either a catenary or trenching for a duct.
I think I already have a unused Intel LAN card on its way to me from a friend in Yorkshire so I'd ask you to hang on to it just in case.
Are there any UK outlets for Mesa cards?
I just used CAT6E because I had a box of it... it's a bit more expensive than CAT5E. I don't know if I'll ever use the 200 MHz of bandwidth that CAT6E has.
02 Jan 2012 12:31 #16207 by Rick G
Replied by Rick G on topic Re:One for the hardware gurus
I ran two CAT5 cables and an extra pull line in conduit out to my shop, works great. Much better in my case than wireless.
Rick G
03 Jan 2012 18:02 #16266 by boldford
Replied by boldford on topic Re:One for the hardware gurus
Reply to ArcEye.
The LAN card from my friend in Yorkshire arrived today. After carrying out the hack to fit a full height card into a half height PCI slot it is up and running fine.
However many thanks for you kind offer anyway.
03 Jan 2012 21:48 #16273 by Harry_Y
Replied by Harry_Y on topic Re:One for the hardware gurus
Rick G
I am a network guy and I only use wireless as a last resort.
Hard wired is the way to go
04 Jan 2012 17:04 #16308 by boldford
As a retired network guy I'm inclined to agree. I am aware of the robustness of a hard wired connection.
I'm now encountering a very strange phenomena. Having initially installed the 10.04 Live CD on the Gateway Flexatxstc BRO 600 it was working fine. Having now received and hacked the fully height LAN card provided by a friend I decided to download and update the patches to 10.04.3 (which took forever).
Bad move! It broke so I'm now putting the 10.04 Live CD back on, as is, and then try and find what my little BRO doesn't like and what of the patches could/should be omitted
Any thoughts from the panel?
05 Jan 2012 09:18 #16323 by ArcEye
I presume you mean you ran the update manager.
Don't.
Ubuntu 10.04 with kernel 2.6.32-122-rtai is the basis of the whole EMC install and what it was built against.
If you 'upgrade' the kernel, it will not be a real time kernel, so EMC will no longer work.
If you upgrade individual applications, you will get away with it with some and not others.
If whatever prompted the new kernel number contained changes that directly affect an application,the new version will have been rebuilt against the new kernel and may no longer work.
If you want to upgrade EMC, that is completely different.
You can run whatever version of EMC you like with the current kernel, 2.4.7 is the latest fully supported release, 2.5.xxx is a pretty stable beta used by a lot of people for features which have not migrated to the 2.4 series and which are used by some setups.
05 Jan 2012 10:13 #16326 by boldford
ArcEye wrote:
. . . . .Don't.. . . . .
And to prevent me making further stupid mistakes again I'm going to be remove the NIC to make it a stand alone machine. G code files can be delivered to the workshop on a pen drive.
It serves me right for trying to be clever. :blush:
Still it'll save having to dig that trench for the network cable I mentioned earlier.
Ho hum.
05 Jan 2012 12:06 #16333 by andypugh
Replied by andypugh on topic Re:One for the hardware gurus
Well... If you can find a way to make the NIC work there are other advantages, like being able to sit inside in the warm and keep an eye on the CNC machine with VNC while it does long jobs.
05 Jan 2012 12:07 #16334 by BigJohnT
Well... the only thing you don't want to upgrade is the operating system. If you go to System/Administration/Synaptic Package Manager you can turn off the prompt for upgrading the operating system. While possible to get upgrades with a pen drive is it much easier to do so with an internet connection. Of course the most important upgrades are the EMC ones.
Time to create page: 0.072 seconds
