HAL Stand Alone configuration
- martinwh99
04 Jan 2012 11:19 #16285
by martinwh99
HAL Stand Alone configuration was created by martinwh99
Hello
I've been reading throw the EMC2 and HAL PDF manuals and I have a view questions if i understood thinks right. Unfortunately i'm a new to the CNC stuff. I want to use HAL for the configuration of my CNC Styrofoam cutter. Which means i have a XY and a UV axes. And i would like to send G-Code. So here are my Questions:
Can i configure such a kind of machine with HAL Standalone (without EMC2) and where to start?
Can i send G-code somehow to HAL?
Sorry if these questions are stupid, but if I find the startpoint for my project I can hopfully fight me thru the rest of it.
Martin
Martin
- BigJohnT
- Thank you received: 1176
04 Jan 2012 12:28 #16287
by BigJohnT
Replied by BigJohnT on topic Re:HAL Stand Alone configuration
No, you will need EMC to process g code.
- Thank you received: 4992
04 Jan 2012 13:31 #16291
Replied by andypugh on topic Re:HAL Stand Alone configuration
martinwh99 wrote:
You might find this interesting:
You could, because that is what EMC2 does, but you would end up having to create your own user interface, G-code parser, trajectory planner and motion controller.Can i send G-code somehow to HAL?
- martinwh99
04 Jan 2012 14:36 #16293
by martinwh99
Replied by martinwh99 on topic Re:HAL Stand Alone configuration
Hello
Thank's for the prompt answer. So i have learnt i will need EMC2 i can not do it with stand alone HAL. So i have to figure out how to define a machine with 4 linear axe YX and UV.
Martin
Martin
04 Jan 2012 14:50 #16294
martinwh99 wrote:
EMC2 is part way through a conversion from having the axes hard-coded to joints, and being a bit more flexible.
This means that some things can be a little confusing.
You should probably start with stepconf (if this is a stepper machine) and then hand-modify the HAL and INI files.
The G-code interpreter will pass the X-position out as axis.0, Y as axis.1, U as axis.6 and V as axis.7, so you need to define an 8-axis machine.
In the INI file you need to clone the [AXIS_0] section so that there is a full set from [AXIS_0] to [AXIS_7]. Don't give the unused axes a HOME_SEQUENCE number, though, and set their home search velocity to zero too.
In the HAL file you will need to add an extra stepgen, but there is no reason at all why axis.7.motor-positon-cmd can't drive stepgen.3.position-cmd.
Have you seen the winch-based foam cutter which uses string and clever kinematics to replace the linear axes?
www.cnc-hotwire.de/
His config files are here:
code.google.com/p/emc2hotwinch/
www.cnc-hotwire.de/
Time to create page: 0.064 seconds
