Way to Tram X Axis in software?
13 Jan 2012 22:45 #16743 by kbailey204
Replied by kbailey204 on topic Re:Way to Tram X Axis in software?
I didn't change the BASE_PERIOD, FERROR and MIN_FERROR for my machine.
13 Jan 2012 22:59 #16744 by kbailey204
Never mind. Set all Velocitys, base periods to same as other config file and getting joint errors whenever I jog.
13 Jan 2012 23:02 #16745 by andypugh
Replied by andypugh on topic Re:Way to Tram X Axis in software?
Stepper? The only reason you ever see an f-error there is if the base period can't keep up with the velocity. (ie not enough steps per second).
If reducing the jog speed doesn't make the problem go away (and the default jog speed in that config is probably in inches) then something properly odd is going on.
14 Jan 2012 15:17 #16766 by kbailey204
That's what I thought too. I have the BASE_PERIOD set the same as a working config file that I was jogging around at 300ipm with no errors. On the gantry sample config, with everything set exactly the same, any jog over 10ipm causes a joint error. Am I missing something, everything I'm comparing is in the ini file.
14 Jan 2012 19:33 - 14 Jan 2012 19:37 #16773 by Rick G
Replied by Rick G on topic Re:Way to Tram X Axis in software?
Last edit: 14 Jan 2012 19:37 by Rick G.
Time to create page: 0.123 seconds
