MINI
26 Jan 2012 19:40 #17171 by hemicro
MINI was created by hemicro
Not sure if this is the right area, but I have been looking at the MINI Graphical Interface info and can't seem to find the download or installation info.
27 Jan 2012 02:41 #17175 by cmorley
Replied by cmorley on topic Re:MINI
Mini comes with the linuxcnc download.
Are you using linuxcnc (formerly EMC2) ?
27 Jan 2012 16:08 #17193 by hemicro
Replied by hemicro on topic Re:MINI
I installed Ubuntu 10.04 LTS Lucid Lynx and EMC2 using a live cd download. The startup screen idicates "Linux 2.6.32" version, so it may be I have an old version of EMC2. If that is the case can I update the EMC2 and I will probably need some direction on how to do it. I have some knowledge, but limited in the Linux system.
27 Jan 2012 17:00 #17196 by ArcEye
Replied by ArcEye on topic Re:MINI
Hi
Ubuntu 10.04 uses the linux 2.6.32-122-rtai kernel, you can't upgrade that.
EMC (linuxcnc) version 2.4.3 is the default from Live CD, currently upgradeable to 2.4.7
Mini is called tkmini
Change your DISPLAY = axis in your .ini file to DISPLAY = mini and start emc, to use it.
27 Jan 2012 17:01 #17197 by cncbasher
Replied by cncbasher on topic Re:MINI
on running pncconf or stepconf , Mini can be selected as the GUI to use duing configuration
or alternatively in your configuration INI file
change the line
DISPLAY = axis
to
DISPLAY = mini
27 Jan 2012 22:38 #17206 by hemicro
I changed the ini file and low and behold, the mini interface runs. Thanks for the help, it saved a huge amount of search time!!!!
