Programs starting automatically!
- justin
31 Jan 2012 04:23 #17291
by justin
Programs starting automatically! was created by justin
I have finally got my retrofit to the point where I am running g-code. Trouble is that the programs will start automatically.
Here is when it will start without my prompting:
-when the program is first opened
-when the program is reloaded
-when i do a work offset (g54 etc.)
-when I touch off a tool.
Seems pretty strange and a safety hazard as well. Any ideas? I have no idea unless I have a stuck button or something like that...
Thanks.
Justin
Thanks.
Justin
- Online
- Thank you received: 2155
31 Jan 2012 07:12 #17293
Replied by cmorley on topic Re:Programs starting automatically!
I've has a similar problem on my laptop with 10.04 from time to time.
still can't tell if its the button or not.
some times openned about 50 windows before i got it to start.
- BigJohnT
- Thank you received: 1176
31 Jan 2012 12:39 #17296
by BigJohnT
Replied by BigJohnT on topic Re:Programs starting automatically!
The only time I've seen strange keyboard responses is when the base thread was too fast for the computer and the cpu was busy 100% of the time with real time... but I've never seen one do something without you pressing a key or a mouse click. Might swap key boards...
- justin
02 Feb 2012 02:05 #17330
by justin
Replied by justin on topic Re:Programs starting automatically!
Thanks, I will check out the keyboard issue. I am also using a keyboard emulator, that might be doing something as well.
Justin
Justin
- BigJohnT
02 Feb 2012 12:05 #17336
by BigJohnT
I do recall something about keyboard emulators being a bit flaky.
Time to create page: 0.064 seconds
