Panel Saw
- Dropout
04 Feb 2012 21:27 #17407
by Dropout
Panel Saw was created by Dropout
Hi All
Has anyone ever used LinuxCNC to control a panel saw?
There is really only one controlled axis and a number of digital outputs.
Thanks.
Thanks.
- BigJohnT
- Thank you received: 1176
04 Feb 2012 23:27 #17408
by BigJohnT
Replied by BigJohnT on topic Re:Panel Saw
I know of one guy that cuts bamboo for fly rods with a dual blade saw with 2 or 3 axes...
- Dropout
05 Feb 2012 01:23 #17410
by Dropout
Replied by Dropout on topic Re:Panel Saw
Does he post here? I love to see his set up.
- Rick G
- Thank you received: 155
05 Feb 2012 10:57 #17427
by Rick G
Replied by Rick G on topic Re:Panel Saw
I would think a panel saw would have at least 2 axis, x and y?
What are the digital outputs?
Can you explain more about the saw?
At any rate it seems Linuxcnc would work fine.
Rick G
Rick G
- BigJohnT
05 Feb 2012 15:06 #17435
by BigJohnT
Dropout wrote:
I think he is a mailing list guy...
- Dropout
06 Feb 2012 04:22 #17449
by Dropout
Hi Rick G
There are two axis, but only one is really controlled. The other is the movement of the saw blade which is just a digital on/off.
The operation is basically this:
Set the X axis.
Clamp the panel
Run the saw blade to the end of the Y axis and return.
Unclamp the panel
Reset the X axis if required.
Continue as required.
Dropout
Set the X axis.
Clamp the panel
Unclamp the panel
Dropout
- Rick G
06 Feb 2012 11:38 #17455
by Rick G
O.K. that sounds simple enough, similar to setting the length of cut on a chopsaw.
I would think just start with a mill configuration.
Any pictures?
Rick G
Any pictures?
Rick G
- Thank you received: 4992
07 Feb 2012 12:27 #17482
Replied by andypugh on topic Re:Panel Saw
- Dropout
07 Feb 2012 14:24 #17487
by Dropout
