How do you setup stepper as a spindle?
- E_M_C_user
12 Feb 2012 06:42 #17622
by E_M_C_user
How do you setup stepper as a spindle? was created by E_M_C_user
Ive looked through one related post in the forum about someone trying to use a stepper as a spindle and someone mentioned something about changing the hal file a certain way.
I am trying to set up a lathe with a stepper as a secondary spindle driver when I want to do threading.
I am not too sure where to start. I used stepconfig wizard to setup a lathe but the spindle doesnt allow for stepper control. Someone mentioned in the other post about adding a 4 axis conventional mill setting and then swapping out the a axis for spindle?
Anyway I am just stuck and wondering if someone can teach me how its done, so that EMC2 can control the spindle speed and even direction if need be when the spindle is driven by a stepper.
Cheers
Cheers
- ArcEye
- Thank you received: 758
12 Feb 2012 10:02 #17625
by ArcEye
Replied by ArcEye on topic Re:How do you setup stepper as a spindle?
Hi
Did you see this, TimG seems to have his sorted and it has hal and ini snippets in the post
www.linuxcnc.org/index.php/english/compo...iew&catid=16&id=3518
Also according to the release notes from July 2010, pncconf: support stepper as spindle was included, albeit I have never used pncconf, but Chris should be able to advise.
- E_M_C_user
18 Feb 2012 22:04 #17803
by E_M_C_user
Replied by E_M_C_user on topic Re:How do you setup stepper as a spindle?
I took a look at that thread already but I cant get it to work? Not sure how to configure it yet?
- Thank you received: 4892
19 Feb 2012 00:45 #17808
Replied by andypugh on topic Re:How do you setup stepper as a spindle?
E_M_C_user wrote:
That seems an odd way to do it, why not fit a spindle encoder and thread in the normal way?II am trying to set up a lathe with a stepper as a secondary spindle driver when I want to do threading.
- Rick G
- Thank you received: 155
19 Feb 2012 11:34 #17822
by Rick G
Perhaps with live tooling and 3d work where you want the spindle to act as a A axis and be able rotate small amounts both forward and reverse?
Rick G
Replied by Rick G on topic Re:How do you setup stepper as a spindle?
Rick G
- BigJohnT
- Thank you received: 1175
19 Feb 2012 13:12 #17826
by BigJohnT
Replied by BigJohnT on topic Re:How do you setup stepper as a spindle?
Do you simply want forward, reverse and RPM control of your spindle or is more complicated control needed?
