m1 behavior
- mhaberler
- Thank you received: 11
19 Feb 2012 20:44 #17844
by mhaberler
Replied by mhaberler on topic Re:m1 behavior
justin wrote:
You can add arbitrary code there as you see fit. This was just an example I dreamed up.
For other parameter, see 'Predefined named parameters' here: www.linuxcnc.org/docs/devel/html/gcode/o...d_named_parameters_a
The following pertain to your situation:
#<_rpm> #<_spindle_cw>#<_spindle_on> #<_spindle_rpm_mode>
- Michael
Thanks Michael!
I just tested the extended m1 and m0 posted, it works great and is exactly what I needed. Would it be possible to record if it was in m3 or m4 before the m1/ m0 and then start the spindle the same direction after the program is started again. I imagine this would be much like how it checks the coolant....
- Michael
- mhaberler
01 Mar 2012 17:49 #18239
by mhaberler
I'm considering merging this code into master.
If there's any feedback or suggested changes, please speak up
-m
-m
- justin
08 Mar 2012 07:10 - 08 Mar 2012 07:11 #18455
by justin
Replied by justin on topic Re:m1 behavior
I think it would be a great addition. I have been testing it and can't see any needed changes. Thanks.
Justin
Justin
Last edit: 08 Mar 2012 07:11 by justin.
- mhaberler
08 Mar 2012 09:06 #18456
by mhaberler
ok, it's in master now.
- Michael
- Michael
Time to create page: 0.050 seconds
