combining manual and cnc usage
- alanb
27 Feb 2012 15:03 #18142
by alanb
combining manual and cnc usage was created by alanb
I am replacing the dc motor on my mill with a 3phase motor + inverter as part of its conversion to CNC. Here in the uk there are several companies that sell inverters together with a remote pendant. My question is can I arrange it so that I can switch between using the pendant for manual use and an output from emc when using cnc and if so how?
Is it as simple as connecting two input sockets (one for pendant and one for computer) between a 2pole multiway switch to allow me to select either one or the other?
Alan
Alan
- BigJohnT
- Thank you received: 1176
27 Feb 2012 15:25 #18146
by BigJohnT
Replied by BigJohnT on topic Re:combining manual and cnc usage
I'm in the middle of converting my BP knee mill from Anilam to EMC and have the spindle connected to EMC and the rest to the Anilam control. So I start the spindle from EMC or rather LinuxCNC and do the rest via the Anilam controller. Could be the same for your situation... I'm using the Automation Direct GS2 series of VFD as LinuxCNC can control the VFD directly via modbus.
- ArcEye
- Thank you received: 758
27 Feb 2012 15:35 #18147
by ArcEye
Replied by ArcEye on topic Re:combining manual and cnc usage
Hi
The pendants supplied with VFDs replace the buttons on the front of the drive for remote use. Depending where you are going to mount the inverter, you may not require a remote pendant at all.
If you do get one, the safest way would be to have an isolating switch along the lines you describe.
Generally pendants include a potentiometer control for speed which has a live feed from the inverter.
However control via LinuxCNC is generally done via a separate 0-10v connection from a speed board or similar.
The pendant will also connect to the 'Enable' line which LinuxCNC will probably use and the 'Forward' / 'Reverse' lines which it definitely will use.
Some inverters will also have torque boost features etc. but generally these days the settings are programmable rather than triggered by wired signal.
A VFD is one of the simplest ways ways of controlling the spindle in LinuxCNC, often just requiring 4 or 5 connections.
Time to create page: 0.055 seconds
