question about image-to-gcode
- alanb
13 Mar 2012 00:28 #18557
by alanb
question about image-to-gcode was created by alanb
I want to wrap an image around a cylinder. Does image-to-gcode only produce cartesian coordinates (XYZ) or is there some setting to allow cylindrical coordinates? I want to output an angle to A axis instead of a Y coordinate. If this is not possible can you point me in the direction of the source code so I can have a go at amending it , to suit my purpose.
Alan
Alan
- ArcEye
- Thank you received: 758
13 Mar 2012 09:08 #18562
by ArcEye
Replied by ArcEye on topic Re:question about image-to-gcode
Hi
As far as I am aware image-to-gcode just outputs XYZ
It is a python script so just open the file in /usr/bin for the source
Time to create page: 0.042 seconds
