Rigid Tapping
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Premium Member
  • Premium Member
20 Mar 2012 15:14 #18666 by grandixximo
Rigid Tapping was created by grandixximo
I have a spindle with an encoder 1pps for round, i'd like to do a G33.1 Rigid Tapping...
I tried to connect the thing but it does not seems to work.
it think it gets stuck at waiting for a spindle index pulse, and i'm not sure how should i connect my encoder
linuxcnc.org/docs/html/examples_spindle.html
i see that there is code for a 100pulse encoder and 1 pulse index
If i just want to use only the 1 pulse how do i change the code, any help?
20 Mar 2012 15:27 - 20 Mar 2012 15:30 #18668 by ArcEye
Replied by ArcEye on topic Re:Rigid Tapping
Hi
see linuxcnc.org/docs/2.5/html/man/man9/encoder.9.html
setp encoder.0.position-scale [count]
where [count] is the number of pulses per unit ie 1 revolution
encoder.0.phase-z is index
encoder.0.phase-a is pulse
you can connect both to the same signal if you just have one pulse being used for both
Last edit: 20 Mar 2012 15:30 by ArcEye.
20 Mar 2012 16:33 #18669 by PCW
Replied by PCW on topic Re:Rigid Tapping
Rigid tapping requires Z tracking through reversals so you need A/B and perhaps index. (not sure if index is needed for rigid tapping)
With a 1 line = 4 count encoder (1/2 circle interrupter and 2 90 degree spaced sensors) A and Index can be the same so only 2 wires are used
I think its very very unlikely that rigid tapping would work with 1 PPR ) even 4 PPR may not do as Z tracking during the reversal is likely not going to be good enouigh
20 Mar 2012 17:12 - 21 Mar 2012 00:37 #18671 by BigJohnT
Replied by BigJohnT on topic Re:Rigid Tapping
I think Mack is the only one to claim that they can tap with 1ppr... or I might be wrong and not know it.
Last edit: 21 Mar 2012 00:37 by BigJohnT.
20 Mar 2012 18:11 #18673 by ArcEye
PCW
JT
Indeed, whilst my answer is factually correct I hope, I have no idea if what you proposed will work.
I once set up a lathe to thread with a single pulse, feeding Z and A. It cut threads, but extremely badly, to the extent that they usually fouled up after several passes and were unusable.
  • grandixximo
  • Premium Member
  • Premium Member
21 Mar 2012 05:13 #18682 by grandixximo
Replied by grandixximo on topic Re:Rigid Tapping
I got it to work with a single pps encoder connected to z and a
only problem i cannot do rigid tapping because i cannot count in reverse since this encoder is only one direction
i think i need A and B as PCW stated, and i'm going to put them...
I was just curios to know if there was a way to use the spindle reverse output to reverse the encoder count direction also, any ideas???
21 Mar 2012 15:38 - 21 Mar 2012 15:40 #18688 by PCW
It cannot be reliable because the timing of the physical reversal is not known so there is the possibility of miscounts (pretty serious with 1 PPR!). I suppose some smart tracking hueristics could be used to interpolate better with 1 PPR but quadrature and more counts is a much better solution
If you want to try a minimal quadrature encoder, the 1/2 circle one might be a good choice (since it only needs 2 wires A/INDEX and B )
This is 4 PPR so 4 times more accurate with a very good velocity mode drive and 16 times more accurate with a torque mode drive!
Last edit: 21 Mar 2012 15:40 by PCW.
