lathe g76 feed jerky
- genec
thanks
Genec
- cncbasher
- Thank you received: 288
also you dont specifiy your hardware , interface etc it all helps to know
what vfd etc is used ?
if this spindle is pwm controlled have you a pwm to analog interface
this could also be the situation that the pwm signal is reversed to what is needed or the fwd/reverse is wrong
- genec
- Thank you received: 2161
what is your base period?
What speed is your spindle running at?
- jmelson
- Thank you received: 159
I'd strongly suggest setting up Halscope and viewing the spindle velocity signalI dont have a vfd as my lathe is original with fixed spindle feeds. I fitted a 60 tooth to the spindle plus 1 tooth for an index. I use zero speed hall effect gear sensors and get 5 volt square waves plus the index pulse. I was hoping the z feed would sync with the spindle. I use regular parallel interface. Everything else works great and I have used it for taper turning and regular x z feeds. Any ideas
to see if there are large variations in the detected speed. Your results
pretty much indicate that is what is going on.
Jon
- genec
I have 2 cnc4pc c10 parallel port cards, the 2nd is used for a home-made mpg which works great.
below is the Hal file:-
# Generated by stepconf at Wed Oct 12 20:54:43 2011
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out 0xa000 in "
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0
loadrt encoder num_chan=2
addf parport.1.read base-thread
addf encoder.update-counters base-thread
addf parport.1.write base-thread
addf encoder.capture-position servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
setp encoder.0.position-scale 60.000000
setp encoder.0.counter-mode 1
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity encoder.0.velocity => motion.spindle-speed-in
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-phase-a encoder.0.phase-A
#net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z
net estop-out => parport.0.pin-01-out
net xdir => parport.0.pin-02-out
net xstep => parport.0.pin-03-out
setp parport.0.pin-03-out-reset 1
net zdir => parport.0.pin-06-out
net zstep => parport.0.pin-07-out
setp parport.0.pin-07-out-reset 1
net max-home-x <= parport.0.pin-10-in-not
net max-home-z <= parport.0.pin-11-in-not
net spindle-phase-a <= parport.0.pin-12-in-not
net spindle-index <= parport.0.pin-13-in-not
net estop-ext <= parport.0.pin-15-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 20000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net max-home-x => axis.0.home-sw-in
net max-home-x => axis.0.pos-lim-sw-in
setp stepgen.1.position-scale [AXIS_2]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 20000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable axis.2.amp-enable-out => stepgen.1.enable
net max-home-z => axis.2.home-sw-in
net max-home-z => axis.2.pos-lim-sw-in
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Thanks for your help
Gene
- genec
At this time I am not sure how to see the signals with the lathe running.Would you give the procedure to do this or point me to the source of this information.
Thank you
Gene
- genec
(I am still learning how to use a forum:( )
- jmelson
OK, you start Halscope from the Machine menu of Axis. First time, it will ask which thread toThank you for this advice as being able to see the signals will point to the problem.
Thank you
Gene
put the sampler on, select the servo thread and 4000 samples. Then, at the bottom of
the screen, you can select the signal, encoder.0.velocity which is the spindle velocity
out of the software encoder HAL component. You will have to fiddle with the vertical and horizontal
scales to get a meaningful display. This velocity should be scaled into revolutions per
second, I think. So, at 60 RPM, you should see a value of about 1.0 with some up/down
jitter. The jitter or sample-sample variation is what you are concerned about.
Jon
- genec
I was able to run halscope and view spindle velocity but was surprised to see the correct dc velocity (rpm) with superimposed large random pulses. These were removed when I switched off the Stepper power supply.
I now know the source of the problem and will now work on it.
My thanks to everybody for your help
Gene
