Can a Fenner servo drive replace a Servo Dynamics?
- drembedded
16 Apr 2012 19:23 #19254
by drembedded
Can a Fenner servo drive replace a Servo Dynamics? was created by drembedded
Can I replace my Servo Dynamics board with this Fenner board? The Z Axis Servo Dynamics SD1525-10 board died on me. I have a spare Fenner SDF1525-16 board.
I believe that the Fenner board supports up to 160Vdc and the Servo Dynamics board is good to 110Vdc. The boards look _very_ similar with the same connectors in the same locations. And I believe that Servo Dynamics may have purchased Fenner at some point (or the other way around)
- Thank you received: 5307
16 Apr 2012 22:14 #19255
Replied by PCW on topic Re:Can a Fenner servo drive replace a Servo Dynamics?
You can certainly give it a quick try by connecting motor and tach and
seeing if the analog input will drive the motor each way
(a 1.5V cell and a 1K series resistor is a good test source)
- drembedded
17 Apr 2012 03:39 #19273
by drembedded
Replied by drembedded on topic Re:Can a Fenner servo drive replace a Servo Dynamics?
Peter, thanks for the suggestion.
Gave it try and didn't let the smoke out
So went fro broke and connected up the 7i77 and was able to move the Z axis with MDI commands.
I suspect that the Fenner sdf1525-16 can have 160 volts as the source. The sd1525-12 can have up to 120 volts. Maybe the difference is that using the Fenner, I may not get as much current so slower rapids (but that's only a guess).
Time to create page: 0.132 seconds
