usb cnc controller
22 Feb 2010 17:30 #1995
by mrendu43
usb cnc controller was created by mrendu43
hi anyone knows can i run usb cnc controler like this one on this site www.planet-cnc.com/ with emc2?
22 Feb 2010 21:39 #1999
by acemi
Replied by acemi on topic Re:usb cnc controller
You don't need this hardware when you use EMC. You can connect the drivers directly to the computer. No need a motion controller between PC and drivers.
23 Feb 2010 01:17 #2011
by tenaja
Replied by tenaja on topic Re:usb cnc controller
I agree that it is rather redundant, and also limits the capability of the system... however, if a PC doesn't have a parallel port, it is one solution. (Although a slow one.)
Personally, I would like to use one of the fpga based cards with emc2, to get high speed.
- Highlander01
26 Feb 2010 07:57 #2069
by Highlander01
Replied by Highlander01 on topic Re:usb cnc controller
I am a new user, my understanding, yes, PCs can do this directly but it seems that there may be challenges with having just the right PC to get good latency.
USB system like Arduino Mega that could buffer and run some gcode might be nice?
Time to create page: 0.072 seconds
