Moving X and Y tangent to Z
21 May 2012 19:46 #20265 by andypugh
Replied by andypugh on topic Re:Moving X and Y tangent to Z
mmt wrote:
woodburn@woodburn-desktop:~$ sudo comp --install kent.c
IOError: [Errno 2] No such file or directory: 'kent.c'
Is there a file called kent.c in the directory where you are invoking comp?
Otherwise you need to give the full path.
22 May 2012 15:01 #20272 by mmt
Replied by mmt on topic Re:Moving X and Y tangent to Z
Thanks Andy. I should have known that. It worked.
One last quick question:
How do I change the program that is loaded when Linux (Axis) opens?
22 May 2012 15:28 #20273 by andypugh
It's an INI file option:
www.linuxcnc.org/docview/html/config/ini...ub_display_section_a
OPEN_FILE
