Having trouble with touch off
- Chipmunk
I am having trouble with the Touch Off function on my mill, I must be doing something wrong. The following is the procedure I am using.
I am using a vise which is mounted on the table and my Z axis 0 would be about 3 inches above the table.
Procedure
I load program that I want to use,
Open it up, axis displays the tool path, the programs run flawlessly when cutting air.
Home X, Y, Z.
Then I perform the touch off function, I use a feeler gauge., I set the offsets in the appropriate box and push OK.
I use G54 for my coordinate, I have also inserted G54 into the preamble of my program.
This is where it gets troublesome,
When I push the run function,
The Z axis moves down and settles out below the bottom of the work, also the X and Y, zero positions do not go to the Touch Off positions.
Obviously there is something I am missing, in the initial setup of EMC2 is there something I should have done and did't.
Am I doing the Touch Off correctly.
Any thoughts would be greatly appreciated.
- jmelson
- Thank you received: 160
(G54, G55, etc.) that will be set. If your program has any G10 L2 Px commands in
it, it will change the coord system and nullify your touchoff setting. And, of course, if
you use G41, G42 or G43 commands, that will offset from the coordinate system
by tool radius or length settings.
I'm wondering why you home after loading the program, I always home when I
start LinuxCNC.
Jon
- Thank you received: 5012
Can you post the first dozen or so lines of your G-code?
Bear in mind that when typing in a number in the touch-off box you are saying what you want to call the current position. So, if your G-code is written with the top of the work as Z=0 then if you have a 0.3mm feeler gauge, when the tool tip is touching the feeler gauge, that is a Z-touch-off value of 0.3mm in G54. If you put the offset in the tool table (T instead of G54 in the touch-off box) then it will set the tool length such that the current axis position is Z = +0.3mm
- BigJohnT
- Thank you received: 1176
Seems I need to write on homing as well... oh wait is it in the general section .
- Chipmunk
Here is the first few lines of the code as it comes from my CAM program. I have not modified it in any way.
G20 G40 G49 M6 T1
G17
M7
G0Z0.7874
G0X0.0000Y0.0000S7000M3
G0X-0.0938Y0.5159Z0.2362
G1Z-0.0625F0.5
G1Y1.0309F3.0
G2X0.0000Y1.1247I0.0938J0.0000
G1X0.7976
G1X0.8354
G1X0.8420Y1.1247
G1X0.8491Y1.1247
G1X0.8565Y1.1247
G1X0.8643Y1.1248
G1X0.8725Y1.1250
G1X0.8809Y1.1252
G1X0.8895Y1.1255
ps When I start up the CNC program it always diverts back to the splash screen showing the carving of the old Logo. Is this normal or have I failed to do something on the original installation?
- Chipmunk
In answer to your question, I just thought that that was the way it was done. The reason I thought that was every time I start up LinuxCNC I get the splash screen showing the carving of the original Logo. I thought it would be better if the splash screen showed my project while I was touching off.
LinuxCNC needs a G43 to load a tool offset after the M6. I think you need to tell your CAM package that.Here is the first few lines of the code as it comes from my CAM program. I have not modified it in any way.
G20 G40 G49 M6 T1
G17
M7
G0Z0.7874/quote] which way round is your Z axis?
Typically it is set up with 0 at the top and -300 (or whatever) at the bottom.
If you touch-off then enter G0Z0.7874 in the MDI window, where does the tool go to? (You probably want to move away from the work for this test)
There is an INI file setting which says which file to load at startup. I don't think there is a way to load the last file.ps When I start up the CNC program it always diverts back to the splash screen showing the carving of the old Logo. Is this normal or have I failed to do something on the original installation?
www.linuxcnc.org/docview/html/config/ini_config.html
Look at the [DISPLAY] OPEN_FILE section.
- BigJohnT
Thanks for getting back to me.
I actually won't matter what program is loaded when you touch off but visually it might help. Until you get used to touching off after touching off move the Z to a location where you expect a certain value to be like even with the top of your material but off the side a bit and look for Z0.000 on the DRO. This check will make sure you have not forgot something in the touch off scheme.
- Chipmunk
Thanks for the comments,
I will try them out next week and get back to you. My wife and I are off camping this weekend and I won't get a chance to play around with the mill until next Tuesday.
Chipmunk
- Chipmunk
I started from scratch and reset up my mill using the comments and suggestions from you people. Needless to say, I found and corrected a number of problems.
First of all I determined what my limits and travel is for each of the axis's and set the limits accordingly in the configuration for my mill. I decided that the bottom left hand corner will be my zero for the X and Y limits and the top of the column will be the 0 for the Z limit. The X travel is 0 to 11.625, the Y travel is 0 to 4.875 and the Z travel is 0 to -5.75. I then jogged all of the axis's to some value that moved them off of the home position and invoked G53 G0 X0 Y0 Z0 , the mill responded correctly.
I then set my G54 tool off set using a 0.0015 feeler gauge. Using the left hand side of the work I set the X offset to -0.0015 the Y offset was set at the bottom of the left hand side to -0.0015 and the Z offset was set to +0.0015 off of the to of the work piece. I then invoked G53 again and all off the axi's went to the home position.
I then edited the program and added G54 to the preamble.
The next move was open up the work program and home all of the axis's , they were already at zero because of the previous G53 command. I started the program and was immediately met with a error message, (Program Exceeds Maximum on the Z Axis) I pushed run anyway,
I then was greeted with another error message (Linear move on line 5 would exceed joint's positive limit.)
That is where I am at now, attached is the the first 24 lines of my Cut 2 D program.
G20 G40 G49 G54 M6 T1
G17
M7
G0Z0 0.7874
G1Z-0.0625F0.5
G1Y1.0309F3.0
G1X0.7976
G1X0.8354
G1X0.8420Y1.1247
G1X0.8491Y1.1247
G1X0.8565Y1.1247
G1X0.8643Y1.1248
G1X0.8725Y1.1250
G1X0.8809Y1.1252
G1X0.8895Y1.1255
G1X0.8983Y1.1259
G1X0.9073Y1.1264
G1X0.9163Y1.1271
G1X0.9253Y1.1278
G1X0.9342Y1.1288
G1X0.9430Y1.1298
G1X0.9516Y1.1310
G1X0.9600Y1.1324
G1X0.9680Y1.1339
G1X0.9756Y1.1355
Could you please have a look at this and advise me as to what to do.
Thanks Chipmunk
