Swits problems
08 Jun 2012 14:27 #20753
Replied by andypugh on topic Re:Swits problems
Frederik wrote:
Is Jumper 5 in place?
Does the arrow next to the X-axis DRO change state when you manually press the switch?
It is a PBX 2 from Probotix.
X is fitted with two sw in series normal closed (NC), start/stop, from Board X through sw and back to 0.
08 Jun 2012 14:39 #20755
by Frederik
Replied by Frederik on topic Re:Swits problems
Yes all jumpers's 1-5.
No, nothing happens when I enable sw, what can I see in Hal Metres/singles.
08 Jun 2012 14:50 #20756
Frederik wrote:
You should see the pin status on parport.0.pin-13-in (for X, if you have used the PBX suggested pinout)
You can open a number of Halmeters, or use the Show Hal Config "Watch" tab.
08 Jun 2012 20:12 #20765
by Frederik
Maybe I should buy a print, it can be, and what is the best print which can?
08 Jun 2012 20:17 #20766
Frederik wrote:
Sorry, can you rephrase that? I am not sure what you mean.
Time to create page: 0.167 seconds
