Plasma cutting machine
07 Jun 2012 05:41 #20697 by anpe
Plasma cutting machine was created by anpe
I m planning to make a plasma cutting machine and have some questions about control.
Is it possible to skip pieces while cutting without changing the program?
May i resume program from arbitrary trajectory point?
07 Jun 2012 11:02 #20703 by BigJohnT
Replied by BigJohnT on topic Re:Plasma cutting machine
You can use run from line if your not using subroutines. What I do for all my plasma cutting is set one corner of the part as XY zero and move to there and use G92 to set that point to XY zero then proceed to cut my part, for multiple parts I just make my part a sub routine and move to the point of the second part and use G92. When using G92 don't forget to cancel it when done.
08 Jun 2012 03:43 #20738 by anpe
Replied by anpe on topic Re:Plasma cutting machine
Thank you for answer
Time to create page: 0.050 seconds
