total mill time
- Frederik
17 Jun 2012 21:24 #21047
by Frederik
total mill time was created by Frederik
Where can we see the total milling time on the Emc2?
- BigJohnT
- Thank you received: 1176
18 Jun 2012 10:12 #21054
by BigJohnT
Replied by BigJohnT on topic Re:total mill time
If you mean the actual time it took to run a program you can add a cycle timer to your pyvcp panel using the time component.
linuxcnc.org/docview/html/man/man9/time.9.html
If you mean a sum of the moves without any acceleration/deceleration or blending considerations then in the Axis menu look at properties.
- Frederik
18 Jun 2012 13:05 #21060
by Frederik
Replied by Frederik on topic Re:total mill time
Hello John,
I think it may be nice to know how long a milling takes before I begin.
- Frederik
18 Jun 2012 17:38 #21062
by Frederik
TTG / Time to go
- BigJohnT
18 Jun 2012 20:51 #21066
by BigJohnT
That is not available unless you run the program through a sim and use the time component. Otherwise you will have to look at the program properties in Axis to see a total of feed and rapid moves less acceleration.
- jmelson
- Thank you received: 158
19 Jun 2012 03:54 #21077
by jmelson
Replied by jmelson on topic Re:total mill time
Frederik wrote:
accurate.
Jon
Click on File / Properties in Axis, and it gives an estimate that is usually prettyHello John,
accurate.
Jon
- BigJohnT
19 Jun 2012 14:32 - 19 Jun 2012 14:34 #21102
by BigJohnT
jmelson wrote:
It can be close when the moves are long and the file is short. The splash screen when ran is within a second or two of the properties estimate. However the following G code file reports a run time of 1 second when you look at properties to run but takes 21 times longer to run on my sim as it never reaches the requested speed due to the maximum acceleration of the config and the short moves. This is a typical of a CAM generated 3-D g code with millions of tiny moves.
accurate.
Jon
G20 F150
G0 X0 Y0 Z0
o<100> REPEAT [1000]
G1 X0.0005 Y-0.0005 Z-0.0005
X0 Y0 Z0
o<100> ENDREPEAT
M2
Last edit: 19 Jun 2012 14:34 by BigJohnT. Reason: ques
Time to create page: 0.205 seconds
