Spindle joint Following error
05 Jul 2012 15:30 #21612 by SRT
Spindle joint Following error was created by SRT
I am retrofitting a Lathe with EMC. 30 Hp Reliance DC motor and spindle drive. My problem is following errors on the spindle joint......If I try to spin the axis by hand with EMC in the run state I get a following error and I attribute it to EMC seeing movement when there is none called out or requested. The second case is when I actually call for spindle movement I get a following error before the spindle gets up to speed. The spindle starts but the following error shuts everything off pretty fast. Any Ideas?
05 Jul 2012 15:35 #21613 by PCW
Replied by PCW on topic Re:Spindle joint Following error
The spindle is normally not a motion axis so following error should not even apply to spindle motion. Can you post yout HAL and INI files?
05 Jul 2012 15:42 #21614 by SRT
Replied by SRT on topic Re:Spindle joint Following error
I will try
File Name: rick.hal
File Size:17 KB
05 Jul 2012 15:43 #21615 by SRT
INI File
File Name: cinlatheini.pdf
File Size:32 KB
05 Jul 2012 15:46 #21616 by SRT
I see I do have it as a motion axis. I do believe that was created through PNCconfig but it was so long ago that I have forgotten that part. I am starting to make major progress but the problems seem to be getting bigger....LOL
05 Jul 2012 15:56 #21617 by SRT
What are my choices of signals except the motion signals? should I be connected to the manual signals?
05 Jul 2012 16:58 #21622 by PCW
linuxcnc.org/docs/2.4/html/examples_spindle.html
Has some open loop examples
(you would have to change the hardware pin names)
05 Jul 2012 17:00 #21623 by andypugh
Replied by andypugh on topic Re:Spindle joint Following error
This is rather odd.
Which axis shows a following error?
Is it possible that the resolver numbers are mixed up? Can you check in machine->show hal config ("Watch" tab, the other tab isn't updated live) that moving the spindle changes the value of resolver.00, and that X and Z are on Resolver.01 and 02 ?
You are one of the very first users of the Resolver driver, so it is possible that there might be a mix-up inside the code.
05 Jul 2012 20:10 #21634 by SRT
My spindle is fine........I was getting feed back on my x axis that was actually my joint error. I was hasty with the error.....because every time I touched the spindle I got the following error. I am goung to move the x axis away from the spindle on the resolver board. Thanks for the help today.
Time to create page: 0.080 seconds
