Linear moving vs M67 command
- Kap1eC
- Visitor
25 Jul 2012 05:04 #22438
by Kap1eC
Replied by Kap1eC on topic Re:Linear moving vs M67 command
Yeap. It's for laser machine. I want to control output power vs M67 command.
- Thank you received: 4992
25 Jul 2012 09:21 #22440
Replied by andypugh on topic Re:Linear moving vs M67 command
Kap1eC wrote:
Are you doing raster or vector images?
Where does your G-code come from?
- Kap1eC
- Visitor
26 Jul 2012 09:31 #22475
by Kap1eC
I write program which breaks any trajectory for part vs defined size. And than I try put in this parts power value.
26 Jul 2012 10:32 #22478
Kap1eC wrote:
If you can generate G-code consisting of long straight moves and circular arcs (rather than approximating arcs as many short straight lines) then you should see better performance.I write program which breaks any trajectory for part vs defined size. And than I try put in this parts power value.
- Kap1eC
- Visitor
31 Jul 2012 09:14 #22624
by Kap1eC
Okay. But how I can change lasers power on the arcs middle?
Now I creating python component, which calculate power value using input variable as coordinate. It's work, but M67 command is easy way.
31 Jul 2012 10:17 #22625
Kap1eC wrote:
I think it would be an unusual requirement, though.
I can see that laser power needs to vary continuously when raster-scanning an image. What sort of process requires power changes in the middle of an arc?
If you want a smooth change in intensity throughout the arc then you could look at making a coordinated Z-move and linking laser power to Z. But that introduces further complications which can be reduced but not elimnated by giving the Z axis enormous acceleration limits and tiny "distance" limits.
I have a feeling that UVW axes might not be included in the kinematics calcs in quite the same way.
It would be an interesting test to run
F100
G0 X0Y0
G1 X1Y0
G0 Z.001
G1 X2Y0
and then
F1000
G0 X0Y0
G1 X1Y0
G0 W.001
G1 X2Y0
In the sim/axis/9-axis config while running Halscope to see if the latter causes less stutter in X motion than the former.
Sadly the originators of G-code never considered the requirements of laser cutters (Laser: 1960. G-code: 1980. No real excuse)
You would need to split the arc into two at the point where the power changes.Okay. But how I can change lasers power on the arcs middle?
F100
G0 X0Y0
G1 X1Y0
G0 Z.001
G1 X2Y0
and then
F1000
G0 X0Y0
G1 X1Y0
G0 W.001
G1 X2Y0
Time to create page: 0.057 seconds
