EMC2 v. 2.5.0 crashing on startup
- Alakazam
I just installed the latest package of EMC (2.5.0) via the linuxcnc-install.sh on Ubuntu 10.04 Lucid Lynx.
That worked pretty well, i could even generate a config with the Stepconf Wizard and in the wizard i could run my stepper motors with this little testing program.
But everytime i try to run EMC you see it loading, but before the window is completely visible it crashes with this errormessage, wich does not tell me too much
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/robert/linuxcnc/configs/demo_sim_cl'
Machine configuration file is 'demo_sim_cl.ini'
INIFILE=/home/robert/linuxcnc/configs/demo_sim_cl/demo_sim_cl.ini
PARAMETER_FILE=demo_sim_cl.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=2961
Killing task milltask, PID=3009
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
/usr/bin/linuxcnc: Zeile 687: 3010 Speicherzugriffsfehler $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2961
PID TTY STAT TIME COMMAND
3009
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 2139.484770] I-pipe: Domain RTAI registered.
[ 2139.484805] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 2139.484813] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 2139.484833] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2139.484841] PIPELINE layers:
[ 2139.484851] d54d1e20 9ac15d93 RTAI 200
[ 2139.484858] c085cb20 0 Linux 100
[ 2139.650283] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2139.651012] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2139.651030] RTAI[sched]: hard timer type/freq = APIC/6215331(Hz); default timing: periodic; linear timed lists.
[ 2139.651041] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 895101000 hz.
[ 2139.651049] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 2139.656844] RTAI[usi]: enabled.
[ 2140.074965] RTAI[math]: loaded.
[ 2140.456110] creating ladder-state
[ 2146.882353] axis[3010]: segfault at 0 ip (null) sp bfda22bc error 4 in _tkinter.so[110000+a000]
[ 2151.746884] RTAI[math]: unloaded.
[ 2152.004356] SCHED releases registered named ALIEN RTGLBH
[ 2152.021079] RTAI[malloc]: unloaded.
[ 2152.120055] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2152.134544] I-pipe: Domain RTAI unregistered.
[ 2152.134583] RTAI[hal]: unmounted.
- BigJohnT
- Thank you received: 1176
If so can you attach the the .stepconf file?
- Alakazam
This is my file (please ignore the z-axis, its not ready yet)
I dont know if you need it but here is the error message form my config
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
Machine configuration directory is '/home/robert/linuxcnc/configs/prototype'
Machine configuration file is 'prototype.ini'
INIFILE=/home/robert/linuxcnc/configs/prototype/prototype.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Killing task linuxcncsvr, PID=4297
Killing task milltask, PID=4344
Cleanup done
/usr/bin/linuxcnc: Zeile 687: 4345 Speicherzugriffsfehler $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4297
4344
[ 6152.283694] I-pipe: Domain RTAI registered.
[ 6152.283737] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 6152.283746] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 6152.283769] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6152.283777] PIPELINE layers:
[ 6152.283787] d4e87e20 9ac15d93 RTAI 200
[ 6152.283794] c085cb20 0 Linux 100
[ 6152.451141] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6152.451832] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 6152.451850] RTAI[sched]: hard timer type/freq = APIC/6215331(Hz); default timing: periodic; linear timed lists.
[ 6152.451861] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 895101000 hz.
[ 6152.451869] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6152.458278] RTAI[usi]: enabled.
[ 6152.875773] RTAI[math]: loaded.
[ 6153.233802] config string '0x378 out '
[ 6161.790936] axis[4345]: segfault at 0 ip (null) sp bfc0804c error 4 in _tkinter.so[110000+a000]
[ 6167.545117] RTAI[math]: unloaded.
[ 6167.828673] SCHED releases registered named ALIEN RTGLBH
[ 6167.845048] RTAI[malloc]: unloaded.
[ 6167.944055] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6167.958691] I-pipe: Domain RTAI unregistered.
[ 6167.958728] RTAI[hal]: unmounted.
- BigJohnT
- Alakazam
Could it be something with the graphics card drivers? Thats my only idea
btw. thanks for the quick response
- BigJohnT
Try and run from the CNC menu LinuxCNC and from the sample configs run sim > tklinuxcnc > tklinuxcnc and sim > keystick. It might also be an opengl problem.
- Alakazam
I guess that means it is the graphics card?
My Graphics Chip is an Intel 82815
I ran "glxinfo | grep direct" and it said "direct rendering: No (LIBGL_ALWAYS_INDIRECT set)"
- Thank you received: 4968
- BigJohnT
- Alakazam
with the documentation i solved the problem, i still don't exactly know what it is,
but installing the software-only OpenGL package helped ( point 5.2 in the documentation if anyone has the same problem)
i can now start the program properly and run my steppers with it
