orientation linuxcnc
21 Aug 2012 21:53 #23516 by andypugh
Replied by andypugh on topic Re:orientation linuxcnc
jlviloria wrote:
I read the information you sent me, the engine has "hall sensor", anyway send an email to support Siemens to confirm.
In that case it ought to be fairly easy to run the motors from an 8i20. I am still hoping that PCW will say whether he thinks that is a good plan or not though.
4. of linuxcnc, I'm making an interface, drives with 3 stepper motors. small (hooby), to familiarize myself more with the software linuxcnc.
That is an excellent idea. Almost nobody keeps their first idea of a config, far better to learn what you really need with a cheap parallel-port system than with a costly servo board set.
5. something that has me worried is the integration of buttons on the machine.
to open and close the chuck, to turn on the pump, cycle start and feed hold .. but I think that will come with time.
That's all really easy stuff. In most cases there are several solutions.
22 Aug 2012 03:17 #23528 by jlviloria
Replied by jlviloria on topic Re:orientation linuxcnc
PCW friend servomotor 22Nm 32.4 amp hall sensor. 8i20 can work with table please help.
thanks ,
22 Aug 2012 16:21 #23557 by jlviloria
Franciso,
creo que tengo la solucion, parece que se puede salvar el simodrives de los motores o por lo menos para dos ejes. el tecnico esta revisando. la pregunta es si se puede salvar, se puede integrar con linuxcnc?
Andy:
Please confirm 8i20 support servomotor.
if you can save the original drives are compatible with linuxcnc
thanks,
Jorge
23 Aug 2012 13:35 #23576 by jlviloria
Hello,
Friends,
I am very happy, I got two SIMODRIVE units, each controlling 2 axes, servo motors are perfect for ... are in good condition. Now the question is linuxcnc suit? Robh told me that they are easy to set ... but I want to confirm.
Well now I get to work, I need to start moving my axes. in everything I've read 5i25 board would think that, but I want to know what you think.
that other board I need to start trading.
thank you very much and sorry for all this trouble.
cordially,
jorge Viloria
18 Sep 2012 13:01 #24363 by mario_rl
Replied by mario_rl on topic Re:orientation linuxcnc
Estimado Jorge,
En el mercado actualmente tienes:
1. Servos síncrosnos, que son motores sin escobillas de imán permanente. a éstos son a los que se le llama de toda la vida "servos". Son caros.
2. Motores de contínua. En desuso, tienen escobillas y presentan rizado de par.
3. Motores de inducción, también llamadosde jaula de ardilla ó asíncronos. Mucho más económicos. Para funcionar como un servo necesitan un variador de frecuencia especial (mas alante explico) y una captación de velocidad (un encoder generalmente). Pueden necesitar ventilación forzada debido a que en modo servo, al rotar despacio, el ventilador que llevan atras da muy poco aire.
Lenze tiene drivers que son capaces de manejar motores tanto síncronos (servos) como asíncronos (de inducción). Estan pensados para adaptarse a cualquier motor siempre que se escoja un modelo capaz de proporcionar la corriente nominal del motor. Abb también tiene modelos que hacen todo eso. Yo personalmente tengo experencia con [motores de inducción+variador Mitsubishi FR-A740+encoder] y van muy bien para posicionado, aunque evidentemente no tiene la dinámica/rendimiento de un servo síncrono. (se calienta mas y no es tan capaz de reproducir cambios muy bruscos de velocidad, como un servo síncrono). Sin enbargo creo que el mitsubishi FR-A740 solo puede manejar motores asíncronos, osea de inducción.
Saludos.
20 Sep 2012 21:12 #24493 by jlviloria
hola, Mario.
Gracias por tu respuesta.
Que buen foro, que buena gente, asombrado de ver tanto talento junto, que buen programa..!!!
Bueno mira, ya tengo definido que voy a usar los motores originales, tengo listo esa parte. Estoy esperando recibir las tarjetas MESA, pedi 5i25+7i77+7i64, por recomendacion de Andy.
Lastimosamente para mi, no tengo experiencia ni LINUX ni en LINUXCNC. ademas de eso me doy cuenta que hay que tener conocimientos claros y concisos de programacion, lenguaje c, c++, python, hasta HAL, segun entiendo maneja su propio lenguaje.
De todas maneras yo sigo avanzando... estoy leyendo cada uno de los hilos del foro para ver que problemas se les presenta a ellos para ir corrigiendo.
Algo que me inquieta, es que mi torno si ves las fotos son de 2 torretas, osea 4 ejes, he visto que se puede hacer un retrofit tranquilamente con 4 ejes. pero no entiendo como hacer para que linuxcnc, entienda que 2 ejes son con radio y diametro. no se si me entiendas.
John ha sido muy amable aclarandome algunas dudas al igual que PCW, robh, francisco, andy y ahora tu.
son muchas las dudas e inquietudes pero vale la pena.
las dudas hasta el momento sin aun tener las tarjetas MESA son:
programacion en classsicladder las dos torretas.
Configuracion de linux para torno con 4 ejes.
Bueno amigo si me puede ayudar con alguna de estas dos cosas seria maravilloso, ya que el ingles no es mi idioma fuerte, me toca recurrir al traductor de google y sabes que hay se desvia mucha informacion.
De antemano muchas gracias por tu atencion
Jorge Viloria
Barranquilla- Colombia
16 May 2020 04:51 #167920 by bmindiola
Replied by bmindiola on topic Re:orientation linuxcnc
Creo que puedes utilizar un motor de inducción y un variador de frecuencia para lo que necesitas, saludos...
11 Jun 2020 18:33 #171164 by bmindiola
Replied by bmindiola on topic orientation linuxcnc
Interesante, gracias por todo. .. .
Saludos
Time to create page: 0.124 seconds
