Intermittent issues with EMC2
14 Mar 2010 04:29 #2304
by ewlsey
Intermittent issues with EMC2 was created by ewlsey
I am retrofitting a 3 axis mill. So far things are working OK.
When starting EMC2, I get a realtime error. I can clear the error and everything will still work, but it is annoying.
I also get intermittent errors while homing. The error say that the switch was active before the start of axis backing off. I get this error only on X and Z axis even though all axes all share a home input. I get the error about every 10th time I home.
Any thoughts?
-Wes
Any thoughts?
-Wes
14 Mar 2010 11:12 #2306
by Rick G
Replied by Rick G on topic Re:Intermittent issues with EMC2
Hello,
You might want to rerun the latency test. You may need to use a more conservative number. It is my understanding that the error code will only appear one time per session, but that does not mean it is happening only one time.
Rick G
Rick G
21 Mar 2010 00:58 #2391
by ewlsey
Replied by ewlsey on topic Re:Intermittent issues with EMC2
Of course you are correct! I just didn't want to believe it.
I switched the steppers to half stepping (from 10 micro-step), and increased the base period. The machine is now faster as well (but of course the trade off is positional accuracy).
Everything works perfectly now.
21 Mar 2010 10:30 #2393
by Rick G
Glad to hear you are up and running. Have fun.
Rick G
Rick G
Time to create page: 0.387 seconds
