Prob Z
16 Aug 2012 13:56 #23291 by gois
Prob Z was created by gois
Good morning!
I'm using Prob in the Z axis and use the MDI as follows: G38.2 Z-3 F200
What I need is the following, create a button with name "Reset Z" button and this enable Prob,
and when playing the card literally ZERO the Z axis in the way that happens when we click the "PROBE".
I know how to create buttons and how to enable them to perform the MDI command, but I do not know how,
perhaps create a macro to perform this process, anyone have any examples of how I do it?
16 Aug 2012 15:32 #23297 by BigJohnT
Replied by BigJohnT on topic Re:Prob Z
Here is how I created a "Rapid to Home" button, it might be similar.
www.linuxcnc.org/index.php/english/compo...=40&id=3408&start=30
16 Aug 2012 18:49 #23312 by gois
Replied by gois on topic Re:Prob Z
Good afternoon!
let me try to explain better ...
What I need is when I click the "probe" for the Z axis, which before referencing the cordenada against the workpiece, which
locate the probe.
Then work as follows in Click on "probe" for the Z axis, and the Z axis encntrar begins to descend to the probe, when receiving the reference tap cordenada over the workpiece G54.
16 Aug 2012 19:24 - 16 Aug 2012 19:25 #23313 by Rick G
Replied by Rick G on topic Re:Prob Z
You can also look here...
www.linuxcnc.org/index.php/english/compo...ew&catid=40&id=17821
Take a look at section for Z
In short...
probe for Z
After probe trips
You can use G10 or G92 to set the z axis to 0.
Rick G
Last edit: 16 Aug 2012 19:25 by Rick G.
16 Aug 2012 20:33 #23314 by BigJohnT
If I understand now your using a probe routine to locate the top of the material?
This is my probe routine for my plasma torch to find the material top.
o<touchoff> sub
(#1 pierce height, #2 pierce delay, #3 cut height)
F10
G38.2 Z-1.75 (Probe to find the surface)
G91
G1 Z0.070 (Raise up to Z0)
G90
G92 Z0 (Set Z0)
G1 Z#1
M3 S1
M66 P0 L1 Q5 (Wait for Arc OK from Torch)
G4 P#2 (Pause for pierce delay)
F25
Z#3 (goto cut height)
o<touchoff> endsub
M2
This could be called from a button like the above example.
20 Aug 2012 20:08 #23434 by gois
Good afternoon!
Its give me an example of how to call it an alert button because I can make the button, but I can only draw one line at a time.
20 Aug 2012 21:59 #23445 by Rick G
Sorry, not sure what you are trying to ask.
Rick G
Time to create page: 0.165 seconds
