External buttons function
- Thank you received: 4992
19 Aug 2012 12:40 #23392
Replied by andypugh on topic Re:External buttons function
raychar wrote:
[quoteNone of mistake found. I just re-type the original code again. And now, it Works! (Will it be the copy and paste problem, better to re-type code
every time???).[/quote]If you copy-and-paste from Windows you might include spurious CR/LF combinations. This can cause problems (but _really_ shoudn't by now).
en.wikipedia.org/wiki/CR/LF#Common_problems
- Miselph
10 Nov 2012 17:16 - 10 Nov 2012 17:17 #26429
by Miselph
Replied by Miselph on topic Re:External buttons function
I used your code above to get some features of my pendant working.
However, I have traced it out on paper and it appears that the two and2 blocks and the or2 block are completely superfluous. What is their purpose? I have tried the code without them and it seems to work. Is there some reason I should leave them in?
my code is:
my code is:
net PauseRunCommand toggle.0.in <= apendant.digital-in-13
net ToggleSignal toggle2nist.0.in <= toggle.0.out
net ProgramPaused toggle2nist.0.is-on <= halui.program.is-paused
net ProgramPause halui.program.pause <= toggle2nist.0.on
net ProgramResume halui.program.resume <= toggle2nist.0.off
Last edit: 10 Nov 2012 17:17 by Miselph. Reason: code clarity
- BigJohnT
- Thank you received: 1176
10 Nov 2012 20:00 #26432
by BigJohnT
Replied by BigJohnT on topic Re:External buttons function
Those are part of a check to prevent an error message if you press the button at an inappropriate time.
Time to create page: 0.056 seconds
