Configuring EMC to substitute U for A in gcode
- Gadget047
Now I need to know if there is any way to configure EMC to take all Gcode lines with A as the axis designation and change it to U. The software I use generates the fourth axis feeds as axis A and EMC is looking for U now. I could just use Gedit to change all but it would be easier if EMC just makes the change on the fly.
Thanks,
Dan
- Thank you received: 5015
You know, it might have just been easier to change the Axis A SCALE so that the answer came out in mm/inch rather than degrees.
But: You can configure LinuxCNC to pass files through a filter before loading them:
www.linuxcnc.org/docs/html/config/ini_co...sub_filter_section_a
It ought to be moderately simple to pass the files through some cunning script to swap all A[Number] to U[Number]
Possibly job for awk.
thread.gmane.org/gmane.linux.distributions.emc.user/28010
- Gadget047
I thought AC and E were always angular. How would you go about changing A to linear. That still might be a better solution.Gadget047 wrote:
Can you explain why you think it matters?
I am not sure it makes sense to have the extruder as a linear axis, as that means that it gets included in the tool speed calculations (Actually, I don't think that UVW are included)
You could leave A as angular and set the scale to steps per mm of filament rather than steps per rev or per degree.
However, you can also set the A axis to LINEAR in the INI file. I actually have no idea what effect this has.
www.linuxcnc.org/docs/html/config/ini_co...d_sub_axis_section_a
- Gadget047
Bottom line is the slicer program is best suited for linear movement calculation. I wanted to keep it apples to apples to keep things simple.
I'm new at 3D printing so it's possible I'm attacking this the wrong way but it made sense to me to keep things the same between the slicer program and the CNC program.
You can still do that with a rotary axis. LinuxCNC wouldn't even know if you calibrated an angular axis in furlongs.The program that slices the stl file feeds the filament in mm. The hob drives the filament and is calculated by how many mm's are moved by one revolution of the hob gear.
But, if it makes you feel better, you can set [AXIS_3] to LINEAR.
The trick is to set the SCALE for that axis correct, but that is steps-per-mm-of-filament, and will work the same regardless of whether the axis is set to angular or linear.
- Gadget047
I tried setting axis 3 to linear before with A but still got the angular indicator in the GUI. I'll play with it and see if I can get A to move the correct amount using scale. Either way, I'm happy with the configurations and am ready to start printing now. Sure is a lot to learn with Linuxcnc but it's really a great program once you get the hang of it.
Thanks again for all your help.
Dan
