Ubuntu Update
28 Aug 2012 02:50 #23700 by Chipmunk
Ubuntu Update was created by Chipmunk
I was updating my machine today and I noticed that I was being prompted to down load Ubuntu 12.04.1. Is there a problem doing this, if I recall there was an issue with updating before.
Chipmunk still chipping away.
28 Aug 2012 07:12 #23701 by ArcEye
Replied by ArcEye on topic Re:Ubuntu Update
Hi
Currently the latest rtai kernel is 2.6.32-132-rtai, this is a rtai version of the kernel from Ubuntu 10.04.
If you 'upgrade' Ubuntu you will lose the ability to run Linuxcnc. I think 12.04 runs a 3.xxxx kernel and there are no rtai versions of that readily available at present.
There is a simulator package that runs on 12.04, if this is just a house computer and you want to write and test code on it only.
linuxcnc.org/dists/precise/linuxcnc2.5-sim/
Available in i386 and AMDx64
Unless you have hardware that will not run properly with 10.04 (lot of new audio, LAN and wireless chips were not supported until 3.xx kernels) stick with that.
29 Aug 2012 19:34 #23753 by Chipmunk
Replied by Chipmunk on topic Re:Ubuntu Update
Thanks for the reply:
I was looking at what my version is : 2.6.32-122-rtai, yours must be a newer version.
Chipmunk
30 Aug 2012 06:06 #23761 by ArcEye
No that's just a typo, fingers too big for the keys probably!
You have the correct kernel version, same as mine
Time to create page: 0.055 seconds
