.plt too .ngc
29 Sep 2012 22:40 #24720 by twscnc
Replied by twscnc on topic Re:.plt too .ngc
thanks for the lenk.
i downloaded it to xp
on my home computer.
i'l try it tomoro in linux.
i thank i found a way to get around the
problum with the dxf file from
vmp.
i design in vmp export to corel 9
as a .ai then export it to a 3.5".
with this converter i can take it to
emc2 as a .ngc :lol: :lol: :lol:
02 Oct 2012 02:21 #24848 by twscnc
i may have jumped the gun a littiebet.
i managed to get the .ngc file to the
cnc computer but i can't find a way to get
the file into emc2.
there as no emport that i can find.
i cant find the flash drive or the 3.5" drive
that will let me open the file.
aney suggestions?
02 Oct 2012 09:47 - 02 Oct 2012 09:53 #24853 by Rick G
Replied by Rick G on topic Re:.plt too .ngc
If you have saved the file as an .ngc and have it on your EMC2 computer.
In EMC2 go to
File
Open
Navigate to the location of your file and click on it.
then
click
Open
or just double click on the file.
Rick G
Last edit: 02 Oct 2012 09:53 by Rick G.
02 Oct 2012 10:03 #24856 by andypugh
Replied by andypugh on topic Re:.plt too .ngc
This is where the trouble starts. I have never managed to find the path to a flash drive in the LinuxCNC file "Open" Dialog.
I have managed to (sometimes) find network drives (via a hidden folder on my desktop called .hgfs or something) .
The File Selection Dialog in Axis is dreadful.
The simplest solution is to copy the files off the USB to your home/nc_files directory in the file manager, and open them from there.
02 Oct 2012 10:42 - 02 Oct 2012 10:43 #24859 by ArcEye
Replied by ArcEye on topic Re:.plt too .ngc
If you are using the Ubuntu system as installed from the CD, the default action when a USB stick is inserted is to mount it.
A temporary directory whose name is either the volume name or the device name is created in /media and it is mounted on that.
An icon is created on the desktop with the same name and unless you have changed it, the file manager pops up showing you the contents.
To find it from Axis, which indeed has a very basic FileOpen dialog, drop down the Directory combo-box and select /
Then select media from the folders in the root directory and your stick will be in it under that temporary name.
If you have changed the gnome system for another as I have, then you need to mount the stick explicitly in /mnt say and open it from there.
It is usually faster and less hassle to copy the files across as Andy says, not least because you will not be able to un-mount the stick until L-CNC is closed if you read directly from it and there is always the danger of corrupting the original rather than a copy.
Last edit: 02 Oct 2012 10:43 by ArcEye.
02 Oct 2012 11:37 #24864 by Rick G
Really?
I normally transfer the files from the usb first, but you can select them from a usb drive by
Go to Open
Go to the right upper corner hit the button to go up the directory tree till you get the top /
Then select
media
Then select your usb drive
Navigate to your file.
Rick G
02 Oct 2012 12:02 #24866 by andypugh
Really?
Yes.
Though thinking about it, the Lathe Controller doesn't seem to mount USB devices as drives no matter what I do, so blaming the File Open dialog may be unfair.
Having to navigate through a cryptically named hidden folder to find network mounted drives is still silly though.
03 Oct 2012 02:47 #24900 by twscnc
you don't know how mutch i appreciste all your help.
is there a program in windows that will do the same
as emc2 (free)?
i can run my cnc programs in windows xp but not in linux.
linux may as well be ritten in chinees for somone with
only a therd grade education.
what litt i know about a computer i learned the hard way.
(witch is not very mutch)
but i will give it a try and see what hapons.
i will let you know if i get aney where with it.
thanks agan for all your help.
03 Oct 2012 09:06 #24902 by Rick G
Many people do their design work in Windows, save the files and then run them on a Linux computer using EMC2.
Good luck.
Rick G
04 Oct 2012 03:32 #24926 by twscnc
i know it can be dun.
i just can't seem to rap this empte
head around how to do it.
i haven't had a chancy to try
the steeps you gave me a day or so ago.
i'll try to get to it tomorrow if i'm not to sick.
i'll let you know how it turns out.
