Motor to driver
20 Sep 2012 12:49 #24455 by jeffie_3
Motor to driver was created by jeffie_3
If I have a 90 v.d.c servo motor and a servo driver that goes from 10 v.d.c to 75 v.d.c. Could they be used together?
20 Sep 2012 15:34 #24465 by PCW
Replied by PCW on topic Re:Motor to driver
If the 10VDC to 75VDC is the servo drives power supply range
and the servo drive can supply enough current for your motor
and the servo drive is designed as a DC motor drive
Then yes, it should work. The 75V limit just means that you can
only reach 75/90 (83%) of the rated maximum motor speed
24 Sep 2012 01:12 #24569 by jeffie_3
Replied by jeffie_3 on topic Re:Motor to driver
So the power supply should not exceed the servo drive of 75 volts d.c.? Match the drive and power supply and not the motor?
24 Sep 2012 02:21 #24572 by PCW
Yes! Exceeding the drivers voltage rating will likely destroy the driver.
Time to create page: 0.063 seconds
