Configurate Slave Axis
- Rick G
- Thank you received: 155
01 Jan 2014 20:03 #42262
by Rick G
Replied by Rick G on topic Configurate Slave Axis
- Thank you received: 4964
01 Jan 2014 21:34 #42264
Have a look in the sample configs at sim/gantry. Gantry-hs should give a better demonstration of how homing to the limit switches works.
There is also a stepper-gantry sample configuration with a parallel port setup included.
The 5axis/5axis sample configuration is also a gantry arrangement which includes a vismach simulation of the machine too.
All these examples have one thing in common, they use the non-trivial gantrykins setup which means that the machines starts up with all axes independent, and they need to be homed before you can switch to the XYZ coordinate system.
(Which you do with the $ key or from the "View" menu.)
For a simple cartesian gantry this is all a little over-complex, and one of the development branches (joints_axes4) contains a "gentrivkins" kinematics module that allows arbitrary mapping of joints to axes without having to switch between "Joint" and "World" mode.
Replied by andypugh on topic Configurate Slave Axis
I too am looking for a solution to drive this two steppers on a gantry axis configuration.
The following user(s) said Thank You: mwe
- mwe
02 Jan 2014 00:16 #42268
by mwe
Replied by mwe on topic Configurate Slave Axis
Thanks for the reply's. I remember now, the kinematics and HAL stuff was being written when I last checked in. I see I have some reading to do to understand how to edit the kins scripts. gentrivkins and the other one are a good place to start. Thanks for the leg up.
Mark
Mark
- Clive S
- Thank you received: 481
03 Jan 2014 18:42 #42315
by Clive S
I started a post here www.linuxcnc.org/index.php/english/forum...with-x-axis-2-joints and from what little I understand that there is no solution as yet (for me anyway with no programming knowledge) to get this sorted.
I have reluctantly had to go to Mach3 for my router. But I wait in hope a solution will come along.
I still would like to thank the people on here that are trying to sort the problem out.
Happy New Year to one and all. ..Clive
Replied by Clive S on topic Configurate Slave Axis
Mark
03 Jan 2014 19:18 #42317
What does Mach3 do about homing "slaved" axes? Do you know what the sequence of events during the homing step?
- Clive S
03 Jan 2014 20:42 #42321
by Clive S
This is what I found :-
Re: Homing Problem - Slave Axis
« Reply #1 on: January 30, 2009, 09:04:52 PM »
Hi, Joepardy
Try this in your "Ref All Home" Button's, I had similar Issues with a X, A, dual Axis system awhile back.
DoButton( 24 ) 'Z Home Axis
RefCombination( 9 ) 'X + A Home
DoButton( 23 ) 'Y Home Axis
Hear's some info to review from some Post's.
"Art wrote....> Common problem. When you home , the slaving is disabled till the home is
> done. This is done to auto-square the gantry of such a system, thats why
> the
> lack of slaving when you stop the homing.. The solution is to make the
> homing go in the correct order. This is done by modifying the Homing
> button.. If you open the 1024.set file in the screen designer and double
> click the "Ref All-Home" button, you will see the code is
> DoButton( 24 )
> DoButton( 23 )
> DoButton( 22 )
> DoButton( 25 )
> This basically calls the Z, then X then Y and A homes. This needs to be
> changed to ..
> DoButton( 24 ) ' this homes the Z
> DoButton( 23) ' this homes the Y
> RefCombination( 9 ) ' this will home the X and A at the same time.
> RefCombination accepts a number where X = 1 , Y = 2, Z = 4, A = 8, you
> simply add the values of the axis
> you wish to home, so X + A = 9..
> The squaring will be automatic and can be adjusted by your settings for
> the home position of the switches..
> Thanks,
> Art
> www.artofcnc.ca
Art also wrote this... and I found the complete "Refcombination" listing here....
"Art wrote.... The home switches, (which may be set to the same input as the limit
switches), are used only for homing. The axis will move to the switch, then
slowly move off.
The program by default does one at a time, because thats the most usual
combination. YOu CAN move any combination at once by editing the RefAll
buttons script. There is a command called RefCombination( n ) which will ref
any combination of the axi s. N is calcuated by adding the following
numbers..
X - 1
Y - 2
Z - 4
A - 8
B - 16
C - 32
Ref X and Y together would be RefCombination( 3 )
What I think is happening is (in my case) X and B are slaved and when homing both drive towards the home switches and then back off independently and set. the two joints are then locked as one for the general running of the machine.
You can adjust each switch to get the correct squaring or set the program to come off each switch by an amount that would square the gantry.
I understand that it is not ideal (its works with SS and my prologic controller board from the lan port.) I am not a fan of Mach3 but needs must
Thanks Andy for taking an interest. ..Clive
Hi, Joepardy
> the
> DoButton( 24 )
> DoButton( 23 )
> DoButton( 22 )
> DoButton( 25 )
> changed to ..
> Thanks,
> Art
> www.artofcnc.ca
slowly move off.
numbers..
X - 1
Y - 2
Z - 4
A - 8
B - 16
C - 32
03 Jan 2014 21:03 #42322
You realise that this is _more_ programming than doing exactly the same thing in LinuxCNC?
The point is that such a sequence might make the squaring temporarily worse mid-sequence, which is why I didn't push it as the solution.
buttons script.
- Clive S
04 Jan 2014 01:20 #42328
by Clive S
Andy I am not sure what you mean as altering the button script is a simple process, and both X and B motors run together and they appear to back of the home switches together. I think you can alter the adjustment in software the amount of backing off each does to square the gantry for the home position.
So if the switches are in the true square positions I don't follow that it will make the gantry rack too much.
Are you saying that this could be done in Linuxcnc and if so would you have the time to point me to the correct way to do it?
I have just realised that I have hijacked this post or is it the same topic. ..Clive
buttons script.
04 Jan 2014 01:56 - 04 Jan 2014 01:59 #42330
Yes, you can do exactly the same thing in LinuxCNC. I don't think that it is 100% the right thing.
It's _nicer_ in the joints_axes4 version of the development branch, but in the current release version you need to set up [AXIS_A] to have the same homing sequence number as [AXIS_Y] (or X, depending on the gantry) then copy and paste the stuff from the configs/gantry/gantry.hal HAL file that mentions gantrykins into your HAL file, replacing the reference to trivkins.
Last edit: 04 Jan 2014 01:59 by andypugh. Reason: Quoted the wrong config file
- Clive S
04 Jan 2014 02:25 #42331
by Clive S
[quote="andypugh" post=42330
Yes, you can do exactly the same thing in LinuxCNC. I don't think that it is 100% the right thing.[/quote]
Is there a more correct way to do it that you know of or is this the best I can hope for at the present time.
I will have a go with Linuxcnc and see if I can fathom it out. Thanks yet again Andy. ..Clive
Time to create page: 0.107 seconds
