spindle rotation based on tool number
- jbunch
- Thank you received: 3
23 Sep 2012 08:21 #24558
by jbunch
spindle rotation based on tool number was created by jbunch
I have a backtool lathe. Is there a way to change the rotation of the spindle based on tool selection.
Jim
Jim
- ArcEye
- Thank you received: 758
23 Sep 2012 08:32 #24559
by ArcEye
Replied by ArcEye on topic Re:spindle rotation based on tool number
Hi
There is always a way!
How do you change tools currently?
- jbunch
23 Sep 2012 14:48 #24561
by jbunch
Replied by jbunch on topic Re:spindle rotation based on tool number
Manual tool change.
- ArcEye
23 Sep 2012 15:44 - 23 Sep 2012 15:49 #24563
by ArcEye
eg
G28
M5
M3T3
G43
M4 (or M3 whichever suits)
I was thinking that you had an ATC where cutting tools and drills required different rotation (ie slant bed lathe).
It would be possible to alter the manual_tool_change component to do similar, but if you are changing the toolholder / tool by hand anyway, not clear about any advantage.
Or, are you actually asking about a toolchange component for your lathe (have just seen on your profile you DO have a slant bed lathe)
In which case would it not be easiest to do it in gcode?Manual tool change.
eg
G28
M5
M3T3
G43
Last edit: 23 Sep 2012 15:49 by ArcEye.
- Online
- Thank you received: 5015
24 Sep 2012 17:51 #24587
Replied by andypugh on topic Re:spindle rotation based on tool number
jbunch wrote:
the "comp" component can set a bit for high-numbers, and that could select a mux2 that switched between positive and negative gains for spindle speed.
I guess you could use high tool numbers for clockwise and low for anticlockwise, then get clever with HAL and the iocontrol.0.tool-number pin.I have a backtool lathe. Is there a way to change the rotation of the spindle based on tool selection.
Time to create page: 0.095 seconds
