emc2 goes in the wrong direction
- twscnc
09 Oct 2012 02:29 #25155
by twscnc
emc2 goes in the wrong direction was created by twscnc
can aneyone help me figure out
how to configure the direction.
for instances.
i can get it to home in the right direction.
but when it trys to cut' it gos into the limet
switches.
i can change things in the wizard and
it will cut right.
but then it won't home in the right direction.
i hit the switches by hand to make i thank it hit
home.
can you help?
for instances.
switches.
it will cut right.
home.
can you help?
- jmelson
- Thank you received: 159
09 Oct 2012 05:05 #25157
by jmelson
Replied by jmelson on topic Re:emc2 goes in the wrong direction
twscnc wrote:
HOME_SEARCH_VEL
the number sets the speed in user units (inch or mm) per second.
The arithmetic SIGN of the number sets the direction.
(you may also have HOME_LATCH_VEL if you have encoder
index pulses feeding back to LinuxCNC, but probably not.)
Jon
Homing direction is set by ini file variablecan aneyone help me figure out
for instances.
switches.
it will cut right.
home.
can you help?
HOME_SEARCH_VEL
Jon
Time to create page: 0.060 seconds
