laser on/off control and dxf 2 gc for laser cutter
23 Oct 2012 12:22 #25665 by fishface
I am currently a very happy LinuxCNC user, having replaced all the electronics of my old Denford Microrouter with a simple stepper control board that is now controlled via the parallel port using LinuxCNC. Many thanks to all contributors to this excellent project.
I have just ordered a cheap A4 sized Chinese 40W laser cutter. I intend to do the same to this; discard the provided electronics and software, and fit a simple stepper controller board and use LinuxCNC again.
I don't yet fully understand:
1) What gcodes are best to turn the laser on and off. I have seen a few posts on this forum recommending different gcodes and different ways of doing it, but I have not yet found anyone who has actually done it. If you have already done this; please tell me how.
2) How to convert from 2D design (DXF files from VariCad or QCad) to gcode, with the correct laser on/off controls embedded. To further complicate this, I am a linux only (debian squeeze) user (no Microsoft thank you). Again, if anyone else is currently doing this, please let me know how.
Thanks in anticipation.
23 Oct 2012 13:33 #25672 by andypugh
Don't be in too much of a hurry to discard the OEM controls. The fact is that LinuxCNC isn't brilliant at laser cutting, especially not at rastering.
M62 and M63 ought to be the corect digital pins. M67 if you require analogue output. (recently fixed)
How to convert from 2D design (DXF files from VariCad or QCad) to gcode, with the correct laser on/off controls embedded..
SheetCAM might be the simplest. There is a Linux version, and a demo.
I don't know what it uses for laser on/off in th EMC2 postprocessor, but Les is occasionally seen around these parts so might be helpful.
02 Nov 2012 03:30 #26194 by fishface
Thanks for your answers andypugh.
Just in case anyone stumbles across this thread in the future:
Supplied electronics and software discarded. Replaced by a simple TDA 3 axis stepper driver and LinuxCNC.
I use a simple shell script to convert from Inkscape SVG to DXF:
for file in "$@"
	do
		echo "Creating ${file/%svg/dxf} from ${file}"
		inkscape -E __svg2dxf_temp.eps ${file}
		pstoedit -dt -f dxf:-polyaslines -xscale 25.4 -yscale 25.4 __svg2dxf_temp.eps ${file/%svg/dxf}
		rm __svg2dxf_temp.eps
	done
I use dxf2gcode by Christian Kohloeffel to convert from DXF to gcode. I simple changed the following two lines in the postprocessor config file:
lin_mov_depth = M62 P0  (digital output on, synched with motion=laser ON on next move)%nl
rap_pos_depth = M65 P0 (digital output off immediately=laser off now)%nl
to make it correctly turn my laser on and off.
Brilliant!
12 Nov 2012 12:36 #26472 by BruceLayne
I'm a month or so behind fishface, so I was glad to see this topic. I'm building an 80W laser, with a 2' X 5' table. I have most of the parts, and my laser tube just cleared customs today and will probably be here tomorrow. I still need to buy the aluminum extrusion and hardware for the frame and the skins, and an exhaust fan, and some small stuff, but I have most of it and I'm about ready to start building. I bought the XY table and I'll be cutting it down a little so it'll go through a door without disassembly, but the rest of the design is completely custom.
I had done enough research about raster graphics to realize that it's a bit of a stretch for LinuxCNC, so I was proceeding with the hardware, figuring I'd cross the raster engraving bridge when I came to it. I don't do much raster engraving, and when I do, it's not dithered photographs. It's generally letters and numbers, and a solid monochrome logo. It occurred to me that I can probably define the beam width as the tool width, and do vector engraving if I can move the head fast enough to achieve a reasonable engraving depth instead of engraving too deeply. In my sparse graphics, it might even be faster than scanning the raster lines with the laser off 90% of the time.
I was very pleased to do more research on Inkscape last Friday night. I grew accustomed to using CorelDraw for my laser projects, and I liked it as a CAD replacement, mostly because I could design in the vector drawing program and then print straight to my friend's laser as a Windows printer. It looks like it won't be much more difficult to design in Inkscape and then generate a G code file, hopefully with vector engraving to avoid the hassles of trying to get LinuxCNC to synchronize the laser ON/OFF with the raster scanning.
12 Nov 2012 15:56 #26473 by fishface
Good luck with your build BruceLayne.
Here are a couple of things that you may find useful:
1) A modification I did to dxf2gcode
2) A thread I found about simulating raster graphics , but I haven't tried this myself yet.
Time to create page: 0.395 seconds
