bobcad v24 users help please
- rmattioda
05 Nov 2012 11:54 #26264
by rmattioda
bobcad v24 users help please was created by rmattioda
I have just purchased a probotix meteor and am using bobcad v24.
I am having issues with posting, saving file and using it in the EMC2 software that comes with the probitix.
any tips?
any tips?
- BigJohnT
- Thank you received: 1176
05 Nov 2012 19:24 #26268
by BigJohnT
Replied by BigJohnT on topic bobcad v24 users help please
Could you be a bit more specific about the "issues" your having?
I used bobcrap once and I'm sorry for you having to try and make that part work.
- rmattioda
05 Nov 2012 23:03 #26284
by rmattioda
Replied by rmattioda on topic bobcad v24 users help please
Well first of all
1. which post processor do I need, I have been using the EMC2 Rev1
2. what is the file extension that needs to be used, I notice in the Bobcad FAQ it uses .ncg for EMC, and when opening the files in EMC2 it asks for .ngc, I have had better luck saving them as .NC (in caps) but the files are hit and miss as far as gettin them to open. most of the time EMC2 errors on "M" codes that are unrecognizable.
everything works fine as far as the robotix machine, and the EMC 2 i have ran the sample file with the marker and the router and it works fine.
I need your jedi skills man!
- BigJohnT
05 Nov 2012 23:38 #26287
by BigJohnT
Well my jedi skills are a bit weak... in the ini file you can add more extensions for LinuxCNC to recognize.
linuxcnc.org/docs/html/config/ini_config...sub_filter_section_a
Yea bobcrap is a crap shoot for sure... if you have a paid copy and get the thousands of upgrade emails from bobcrap they should supply you with a working post. If the EMC post won't work try a generic Fanuc post.
Are you machining complicated artsy stuff or just 2-d?
- rmattioda
06 Nov 2012 00:23 #26289
by rmattioda
Just 2d stuff, so you are saying to use the Fanuc post that comes with the Bobcad V24?
- BigJohnT
06 Nov 2012 00:37 #26291
by BigJohnT
Well, give the Fanuc post a try if the EMC post will not work.
Might be faster to just write the G code by hand than to try and get bobcrap to work.
Also for 2-d there is Sheetcam and I think you can get the Linux version with no restrictions.
- rmattioda
06 Nov 2012 02:39 #26296
by rmattioda
do you have the link to Sheetcam,. is it free?
- rmattioda
06 Nov 2012 02:40 - 06 Nov 2012 02:46 #26297
by rmattioda
Will sheet cam allow you to draw, or do you import the dxf from a CAD program and post from sheet cam?,..
Last edit: 06 Nov 2012 02:46 by rmattioda.
- BigJohnT
06 Nov 2012 02:54 #26298
by BigJohnT
Sheetcam is mostly for cam but I think you can draw in it but I've never tried.
sheetcam.com/downloads.shtml
Qcad is free and you just need to install it from the software menu.
Sorry to be so down on bobcad but it was the first cad cam program I tried and I'd rather not talk about it now
- tkamsker
- Thank you received: 5
06 Nov 2012 15:48 #26300
by tkamsker
Replied by tkamsker on topic bobcad v24 users help please
Hi
I did Use V24 and now V25 i have an EMC2 Metric Postprocessor which the Bobcad guys did for me.
I think for a windows program it works ok. But also must say that the guys have been verry helpful with all the issues i had.
And living in and different timezone (GMT+1 ) helps with the sales guys.
so if you did buy it the help you with the postprocessor. I will for instance open an call today because when i try on the lathe an "negative ball" shape
the code looks ok but Linuxcnc doesnt like it
- so their bussiness to fix it.
cu
thomas
Ps: If you need more info drop me an line
Pps: And for 2d Cut2d is sufficient if you dont run an toolchanger
PPS: Did you try Heeks CAD ?
cu
thomas
Time to create page: 0.071 seconds
