lost g code
- ramhobbies
09 Nov 2012 13:00 #26395
by ramhobbies
lost g code was created by ramhobbies
I accidently deleted the g code for Sherlines emc2 pre loaded code for drilling 6 holes 60 degrees apart. I believe its called ( circle hole ngc ). When you open up sherlines inch mill, it is in the list of pre loaded g codes. Can anyone copy the code and post it so that I may re load it.
- cncbasher
- Thank you received: 288
09 Nov 2012 19:59 #26406
by cncbasher
Replied by cncbasher on topic lost g code
here you go
The following user(s) said Thank You: ramhobbies
Time to create page: 0.048 seconds
