git problem installation patch
- jlviloria
- Thank you received: 12
14 Nov 2012 03:26 #26544
by jlviloria
git problem installation patch was created by jlviloria
I have already installed git
and have applied the patch, but I get this:
Configurando git-gui (1:1.7.0.4-1ubuntu0.2) ...
Configurando gitk (1:1.7.0.4-1ubuntu0.2) ...
cnc@ubuntu:~$ git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
Initialized empty Git repository in /home/cnc/linuxcnc-dev/.git/
remote: Counting objects: 112583, done.
remote: Compressing objects: 100% (26669/26669), done.
remote: Total 112583 (delta 88820), reused 108081 (delta 84939)
Receiving objects: 100% (112583/112583), 60.93 MiB | 202 KiB/s, done.
Resolving deltas: 100% (88820/88820), done.
cnc@ubuntu:~$ cd linuxcnc-dev
cnc@ubuntu:~/linuxcnc-dev$ git am --signoff 0001-Fanuc-style-tool-change-for-Lathes.-On-Fanuc-control.patch
Applying: Fanuc-style tool change for Lathes. On Fanuc-controlled lathes (as well Fanuc-like lathes like Haas, Okuma, and likely others). tool changes are not commanded with an M6, and offsets are not applied with G43. Rather the T word both commands a tool change and applies offsets. The offsets on Fanuc lathe controls are stored in two separate registers: geometry and wear. The wear offset register has IDs in the 1-99 range, the geometry offset register has IDs in the 10001 - 10099 range. A T word followed by one or two digits causes a tool change and applies only the geometry offsets. A T word with three or four digits also applies the wear offsets.
/home/cnc/linuxcnc-dev/.git/rebase-apply/patch:41: trailing whitespace.
CHP((find_tool_pocket(settings, geo_offset_register, &index)));
/home/cnc/linuxcnc-dev/.git/rebase-apply/patch:45: trailing whitespace.
CHP((find_tool_pocket(settings, wear_offset_register, &index)));
/home/cnc/linuxcnc-dev/.git/rebase-apply/patch:50: trailing whitespace.
/home/cnc/linuxcnc-dev/.git/rebase-apply/patch:74: trailing whitespace.
warning: 4 lines add whitespace errors.
I can do to solve this problem?
then I should do? to see the tool table as fanuc?
- BigJohnT
- Thank you received: 1176
14 Nov 2012 03:39 - 14 Nov 2012 03:39 #26546
by BigJohnT
Replied by BigJohnT on topic git problem installation patch
Just ignore the warning.
I think you have to put something in the ini file for the patch to work.
Last edit: 14 Nov 2012 03:39 by BigJohnT.
- jlviloria
14 Nov 2012 03:42 - 14 Nov 2012 04:08 #26547
by jlviloria
Replied by jlviloria on topic git problem installation patch
friend after I apply the patch. I need other step?
I must open the 2.6.0pre version? because it opens the version 2.5.0?
thanks.
thanks.
Last edit: 14 Nov 2012 04:08 by jlviloria.
- VNR
- Thank you received: 7
14 Nov 2012 04:38 #26552
by VNR
Replied by VNR on topic git problem installation patch
Has compilado e instalado ?
De memoria, puede no ser "exactamente" asi:
cd src
./autogen.sh
./configure --prefix=/usr/bin
make
sudo make install
OJO, el --prefix=/usr/bin/ reemplazara tu LinuxCNC actual, hay otra forma que es
cd src
./autogen.sh
./configure --enable-run-in-place
make
sudo make setuid
cd ..
. scripts/linuxcnc-environment
linuxcnc
Saludos,
Victor
cd src
./autogen.sh
make
sudo make install
cd src
./autogen.sh
make
sudo make setuid
cd ..
linuxcnc
Saludos,
Victor
The following user(s) said Thank You: jlviloria
- jlviloria
14 Nov 2012 04:58 - 14 Nov 2012 05:24 #26554
by jlviloria
victor
acabo de hacer el primer procedimiento y ahora linuxcnc no me abre.
que puede haber mal?
gracias
cnc@ubuntu:~$ linuxcnc
LINUXCNC - 2.5.0
Error in startup script: couldn't load file "/usr/lib/tcltk/linuxcnc/bin/../linuxcnc.so": /usr/lib/tcltk/linuxcnc/bin/../linuxcnc.so: undefined symbol: _ZN7IniFile4FindEPKcS1_i
while executing
"load [file join [file dirname [info script]] linuxcnc[info sharedlibextension]]"
(file "/usr/lib/tcltk/linuxcnc/bin/../linuxcnc.tcl" line 59)
invoked from within
"source [file join [file dirname [info script]] .. linuxcnc.tcl]"
(file "/usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl" line 29)
gracias
LINUXCNC - 2.5.0
while executing
invoked from within
Last edit: 14 Nov 2012 05:24 by jlviloria.
- jlviloria
14 Nov 2012 06:50 #26559
by jlviloria
It manages to open linuxcnc 2.6.0-pre. but opened only for the terminal. this is correct?
anyone can help me with the part of INI.
I think it is not hard but it looks like I'm not doing well. I'm testing with sim-lathe. to see if the tool-table but nothing changes.
My understanding is only add the line FEATURES = 64 to the RS274NGC section of your INI file
this is correct?
ini file
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
FEATURES = 64
PARAMETER_FILE = linuxcnc.var
this is correct?
ini file
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
FEATURES = 64
- Thank you received: 2162
14 Nov 2012 14:29 #26572
Replied by cmorley on topic git problem installation patch
yes thats it.
then go to MDI and try T02 (assuming you have a tool 2 in the tool file)
If the machine does a tool change (without using M6) then its working
- VNR
14 Nov 2012 18:02 #26578
by VNR
Sorry i did a mistake in the --prefix parameter, i was not in my machine when i wrote that procedure, to fix it you must do:
cd linuxcnc-dev/src
make clean
./autogen.sh
make
sudo make install
check the DATE with: ls -l /usr/bin/linuxcnc
running /usr/bin/linuxcnc you should see "LINUXCNC - 2.6.0~pre" or similar, and will pop up the configurator selector
Sorry for the mistake,
Victor
(Escribo en ingles por si alguien quiere responder tambien)victor
gracias
cd linuxcnc-dev/src
make clean
./autogen.sh
make
sudo make install
Victor
Time to create page: 0.072 seconds
