MPG question
- jlviloria
- Thank you received: 12
24 Nov 2012 08:57 #26885
by jlviloria
MPG question was created by jlviloria
Hi guys,
I have a question regarding the mpg.
I really liked this:
www.cnc4pc.com/Store/osc/product_info.ph...h=40&products_id=254
The question I have is this.
as everyone knows, LOL
I have a kit 5i25, 7i77 and 7i64
but I have only one PCI slot, which is hosted the 5i25.
mpg as I can connect to my machine? I need another board?
Thanks.
Thanks.
- Thank you received: 5263
24 Nov 2012 09:25 - 24 Nov 2012 09:37 #26886
Replied by PCW on topic MPG question
Well looks like that runs on a parallel port so if the PC has a parallel port it should be usable.
The other option is to use the second 5I25 port as GPIO (This needs a header/DB25 adapter cable).
This would require setting up a base thread to read the MPG dial
Yet another option would be to use 7I77 I/O pins and a spare 7I77 encoder to interface to a generic MPG dial and switches
Last edit: 24 Nov 2012 09:37 by PCW.
- jlviloria
24 Nov 2012 09:45 #26887
by jlviloria
Replied by jlviloria on topic MPG question
how I can do this? some examples? thanks peter.
- awallin
24 Nov 2012 18:14 #26894
by awallin
Some notes I wrote down back in 2006
www.anderswallin.net/2006/11/jogging-emc2/
You will need to be a bit familiar with HAL to make use of my notes - going through the tutorials in the manual is one way to learn.
Replied by awallin on topic MPG question
The following user(s) said Thank You: jlviloria
- jlviloria
24 Nov 2012 22:56 - 24 Nov 2012 23:14 #26901
by jlviloria
Awallin
You have an amazing web ... great work congratulations. I will study to see if I can do this. but my knowledge of HAL level is very low. but I'm studying.
thanks.
Peter:
this would not be compatible with my kits?
7I80DB Ethernet Anything I/O card
Thanks.
Jorge
thanks.
Peter:
Thanks.
Jorge
Last edit: 24 Nov 2012 23:14 by jlviloria.
- Thank you received: 4992
26 Nov 2012 16:53 #26949
Replied by andypugh on topic MPG question
Currently this does not work at all with LinuxCNC.7I80DB Ethernet Anything I/O card
Time to create page: 0.523 seconds
