G-CODE FROM gEDA NOT WORKING
04 Dec 2012 09:23 - 04 Dec 2012 10:11 #27168 by miguelcaf
G-CODE FROM gEDA NOT WORKING was created by miguelcaf
Hi!
I'm trying paste the G-Code generated in gEDA to my virtual mill, BUT the G-Code generated is Gerber Model 4X00. How can I get G model that AXIS 2.5.1 understand?
Regards. :)
Last edit: 04 Dec 2012 10:11 by miguelcaf. Reason: Clarification
04 Dec 2012 10:34 #27172 by PCW
Replied by PCW on topic G-CODE FROM gEDA NOT WORKING
Gcode and Gerber photoplotter code are not the same
(though they come from the same roots)
There are conversion programs available:
Google for 'Gerber to Gcode'
The following user(s) said Thank You: miguelcaf
  • djdelorie
  • Junior Member
  • Junior Member
04 Dec 2012 10:40 #27173 by djdelorie
Replied by djdelorie on topic G-CODE FROM gEDA NOT WORKING
gEDA/PCB does have a gcode exporter, too, but make sure you're using the latest development version as there's been a lot of work there recently.
04 Dec 2012 14:13 - 04 Dec 2012 14:15 #27179 by miguelcaf
Replied by miguelcaf on topic G-CODE FROM gEDA NOT WORKING
Thanks PCW and DJDelorie,
I searched for gerber to gcode but all programs that i install dont make the promissed. Have you a converter that work?
Last edit: 04 Dec 2012 14:15 by miguelcaf.
Time to create page: 0.064 seconds
