5i25/7i76 to gecko201 wiring questions?
- BigJohnT
- Thank you received: 1175
08 Mar 2013 08:24 #31056
by BigJohnT
Replied by BigJohnT on topic 5i25/7i76 to gecko201 wiring questions?
Ken,
The 7i76 card needs 24vdc power to the field power. When this is not present the 5i25 does not "see" the 7i76 so nothing will work.
gnipsel.com/linuxcnc/configs/index.html
- Thank you received: 5164
08 Mar 2013 08:37 #31057
Replied by PCW on topic 5i25/7i76 to gecko201 wiring questions?
As John T. mentioned, you only want to connect to the 201's STEP/DIR and COMMON pins
- customcutter
08 Mar 2013 11:36 #31065
by customcutter
Replied by customcutter on topic 5i25/7i76 to gecko201 wiring questions?
OK, just to confirm that I have it right.
3 leads from the 7I76 for each axis. X, Y, & Z axis equals 9 leads. No ground wires from 7I76 TB2 to 201's.
From BigJohnT'sTutorial page "The 7i76 I/O needs 8 - 32vdc field power connected to TB1 Pins 1(+) and 8(0vdc) to work."
Can I simply use a 24V transformer and bridge rectifier to input 24VDC to pins 1 and 8 on TB1? I'm not sure what the (0vdc) on pin #8 is? I don't want to assume that it is the negative from the 24vdc?
thanks,
Ken
thanks,
Ken
Time to create page: 0.136 seconds
