Newbie question about press brake
- alfred_j_kwak
12 Dec 2012 00:19 #27590
by alfred_j_kwak
Newbie question about press brake was created by alfred_j_kwak
So I'm brand new in here and also with LinuxCNC so I have plenty of questions.
I was today fixing quite old Safan hydraulic press brake and started to think that if it is possible to replace old control system with Linux CNC. I tried to do search, but found nothing about press brakes. Is it even possible to control hydraulic press brake with Linux?
Oh and I'm sorry about my writing, I'm fluent with finnish.
-Jussi-
-Jussi-
- BigJohnT
- Thank you received: 1177
12 Dec 2012 00:23 #27591
by BigJohnT
Replied by BigJohnT on topic Newbie question about press brake
LinuxCNC doesn't know what type of machine you have. I assume you have two things to control the press and the back gauge. Seems simple enough if you have a way to drive the valves and get position feedback.
- alfred_j_kwak
12 Dec 2012 00:34 #27593
by alfred_j_kwak
Replied by alfred_j_kwak on topic Newbie question about press brake
Nice,
There is some kind of proportional valves - two cylinders - two valves. And both of those cylinders have 5k slide potentiometers. Back gauge is Lenze servo motor with some kind of control card. LinuxCNC should control simultaneous movement of those cylinders - I suppose that one would be master and other one slave.
-Jussi-
-Jussi-
- Thank you received: 5018
12 Dec 2012 04:44 #27602
Sounds like fun, and eminently possible.
I am using Lenze servo motors on my milling machine. Do you know what form of control input the motor drivers use? If it is analogue voltage then it is all fairly easy.
The motors probably use resolvers, so keeping the original drive cards is likely to be easiest. (Though I am using non-original drives and a resolver conversion card, and that works nicely too, but at greater expense)
Replied by andypugh on topic Newbie question about press brake
two cylinders - two valves. And both of those cylinders have 5k slide potentiometers. Back gauge is Lenze servo motor with some kind of control card. LinuxCNC should control simultaneous movement of those cylinders - I suppose that one would be master and other one slave.-
Time to create page: 0.099 seconds
