Problems with Home Action
- diegoroman17
17 Dec 2012 22:47 #27803
by diegoroman17
Problems with Home Action was created by diegoroman17
Hi everybody,
I have two problems with my CNC Laser. These are small but make my machine look ugly.
First, when I homed my machine it move the axes but stops at certain intervals until the home, why do it?
Second, Sometimes the machine does not give home all axes, the axes move home but the home flag is not changed. Now I have to give the home button a few times to get really achieve in home.
Thanks for help me.
Thanks for help me.
- Thank you received: 5291
17 Dec 2012 23:23 #27805
Replied by PCW on topic Problems with Home Action
Sounds like an electrical noise problem with your home switch signals.
If it is, you can either filter the noise out
with hardware:
Install a .01 uF capacitor from the home switch signal to GND
or software:
feed the home switch signal(s) through the debounce component in HAL
set to maybe 3 servo cycles
with hardware:
or software:
The following user(s) said Thank You: diegoroman17
- diegoroman17
18 Dec 2012 02:00 #27810
by diegoroman17
Replied by diegoroman17 on topic Problems with Home Action
Thanks PCW. My problem was solved with your suggestion. Effectively remove debounce by software and the machine cease to stop and always finds the home.
