Rx and Tx input output of 7i78
25 Dec 2012 00:39 #28014 by diegoroman17
Rx and Tx input output of 7i78 was created by diegoroman17
Hi everybody,
Can you help me with a dude? is possible use RX pin of 7i78 card how a general purpose input and TX pin How General purpose output?
25 Dec 2012 01:19 #28017 by PCW
Replied by PCW on topic Rx and Tx input output of 7i78
The TX output is easily used as a GPIO output
(the TX- pin will be an inverted copy of the TX+ pin)
the RX pin is not so easy to use as its a
differential input and has a 120 Ohm termination resistor
across the input pair, You can use the 7I78 encoder inputs as GPIO
input pins in TTL mode
25 Dec 2012 02:32 #28019 by diegoroman17
Replied by diegoroman17 on topic Rx and Tx input output of 7i78
mmm I have used all enconder inputs. I have used my 7i76 only for one input more jjjj it is really bad. Thanks my friend. Merry Christmas
25 Dec 2012 02:45 #28020 by PCW
Not sure why you need the 7I78 inputs, you have 32 inputs available on the 7I76
Merry Christmas to you as well
26 Dec 2012 00:51 #28026 by diegoroman17
The reason is cost and size 7i78 is cheaper that 7i76 and minor size. What about use how input step or dir signals?
26 Dec 2012 01:37 #28028 by PCW
The step/dir signals on the 7I78 are output only
Another option if you want the most flexibility is to use a 7I75. Then any pin can be used as you wish. You can also use standard parallel port type breakout boards (probotics,cnc4pc etc)
27 Dec 2012 01:28 #28049 by diegoroman17
Is posible use 5i25 with 7i75 and generate a output of pwm? I need control three axis of stepper motor, one pwm output for my power laser source, 5 input of general purpose, 3 output of general purpose.
27 Dec 2012 02:19 #28053 by PCW
Sure, but you have to be OK with 3.3V signals since the I/O is just the FPGA pins directly (with protection)
Time to create page: 0.095 seconds
