New to linuxcnc
- irishjam
04 Jan 2013 22:12 #28378
by irishjam
New to linuxcnc was created by irishjam
Hi All,
New to this forum and linuxcnc. I have some questions.
I have 2 cnc routers and 1 cnc lathe and 1 cnc mill all running mach3.
I have plans for a 5 axis machine and need a better controller with TCP etc and encoder input.
The main thing to begin with is how easy it would be to convert to linuxcnc and what parts will be required.
Any help will be apperciated.
- BigJohnT
- Thank you received: 1176
04 Jan 2013 22:26 #28380
by BigJohnT
Replied by BigJohnT on topic New to linuxcnc
If these are stepper machines I can convert the mach xml file to a stepconf wizard file that will generate the basic configurations. The only thing you need to do is run the latency test and input that number into the stepconf wizard as mach doesn't know about latency.
- irishjam
05 Jan 2013 00:27 #28383
by irishjam
Replied by irishjam on topic New to linuxcnc
Thanks John,
All my mills use dmmtech servo systems inc there bob, these are controlled by step and direction, and closed loop through the driver.
Do i need any other hardware?
john
john
- cncbasher
- Thank you received: 288
05 Jan 2013 01:16 - 05 Jan 2013 01:29 #28384
by cncbasher
Replied by cncbasher on topic New to linuxcnc
I would think as your already running Mach3 via the parrell port , then you should be fine and just need John to convert the Mach3 configuration for you
would be the quick way to get up and running ,
if this it the bob your using
www.dmm-tech.com/Files/DMB4250-8B_BreakoutVer010106.pdf
then we are correct it's just a config needed either convert an existing mach3 , or generate a new one using stepconf in linuxcnc , and you shouldbe up and running
regards and welcome to Linuxcnc
Last edit: 05 Jan 2013 01:29 by cncbasher.
- BigJohnT
05 Jan 2013 01:18 #28385
by BigJohnT
If it is controlled by the parallel port it should be a straight forward swap out.
- irishjam
05 Jan 2013 03:07 #28387
by irishjam
Thats the one cncbasher.
John, I will send you the files tomorrow and let you weave your magic.
Many thanks everyone for your help so far.
- BigJohnT
05 Jan 2013 03:32 #28388
by BigJohnT
You can just attach the xml files to this post and I'll convert them with my magic converter.
Time to create page: 0.149 seconds
