Spindle scaling factor
17 Jan 2013 22:04 #28774 by BigJohnT
Replied by BigJohnT on topic Spindle scaling factor
I don't see any attachment in the new thread... comment out any offending lines and run your config then open up the show hal configuration window then see what type the analogout pin is.
What error do you get when you try to set the scalemax to 400 or 400.0?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
22 Jan 2013 20:48 #28961 by andypugh
Replied by andypugh on topic Spindle scaling factor
When I setp hm2_5i25.0.7i77.0.1.analogout2-scalemax 400/ 400.1, it works, but I need these to select automatically when I change gears
The problem here is that that is a parameter, not a HAL pin. You can use "setp" to set the value of both HAL pins and Parameters, but only pins can be linked together in HAL.
It is not possible to do what you want to do in the way that you have been trying to do it.
You have probably already spotted that the HAL "gearchange" component (www.linuxcnc.org/docs/html/man/man9/gearchange.9.html) is not suitable if you have more than 2 gears.
There are a couple of multi-gear components in this email thread:
thread.gmane.org/gmane.linux.distributio...evel/4043/focus=4238
But you would need to compile/install them yourself using "comp". (Though that isn't very difficult)
21 Sep 2014 03:09 #51385 by PKM
Replied by PKM on topic Spindle scaling factor
Thanks for the link!
I've been trying to use Les' spindle component and I can't find how to set the gears number.
The component loads but there's no "gears" pin or parameter
I also tried
loadrt spindle gears=2
with no success
21 Sep 2014 04:38 #51386 by PKM
I also tried
with no success
Oh, it should be
loadrt spindle numgears=2
andypugh,
How can I get your gearchange component? I'd like to try it too, but I'm not so good with the patches...
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
22 Sep 2014 06:53 #51415 by andypugh
Forget mine, I gave up on it. It seemed to be impossible to get it accepted.
